<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Inflation reveal]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I have made some inflating text, using a number of tutorials.<br />
https://www.youtube.com/watch?v=Ax9GtPLvVIU</p>
<p dir="auto">I have a decent inflation, which moves from top to bottom, but I am trying to think of a way for the text to be revealed.<br />
The majority of the guidance I am following ONLY shows what EJ has done above, I also followed Ellie's tutorial on inflation.</p>
<p dir="auto">The animation I am doing only uses a single character, I am trying to figure out a way for it to look like it is inflating from nothing, like a magical rubber ring inflating out of thin air.<br />
Any ideas would be helpful/.</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/1018/inflation-reveal</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 15:37:59 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/1018.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 Mar 2024 18:50:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Inflation reveal on Wed, 06 Mar 2024 17:31:41 GMT]]></title><description><![CDATA[<p dir="auto">Hi tie-version,</p>
<p dir="auto">The project file has only a link to an Alembic file, while the Alembic file is not provided.</p>
<p dir="auto">Please share it via DropBox, Adobe, Apple, Google, or Wetransfer; thank you.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3655</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3655</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 06 Mar 2024 17:31:41 GMT</pubDate></item><item><title><![CDATA[Reply to Inflation reveal on Wed, 06 Mar 2024 14:15:52 GMT]]></title><description><![CDATA[<p dir="auto">Above is my scene, I have built it based on a cloth sim. I am happy with the inflation, but want to think about how it could reveal.<br />
At the moment, it just inflates from a flat object. I think I want some some of field based reveal that scales the mesh up.<br />
I've tried a few options but they are either problematic or don't look great.<br />
Advice is always welcome.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3652</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3652</guid><dc:creator><![CDATA[tie-version]]></dc:creator><pubDate>Wed, 06 Mar 2024 14:15:52 GMT</pubDate></item><item><title><![CDATA[Reply to Inflation reveal on Wed, 06 Mar 2024 14:13:29 GMT]]></title><description><![CDATA[<p dir="auto"><a href="/assets/uploads/files/1709734364402-animationsample.c4d">AnimationSample.c4d</a></p>
]]></description><link>https://cineversity.forums.maxon.net/post/3651</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3651</guid><dc:creator><![CDATA[tie-version]]></dc:creator><pubDate>Wed, 06 Mar 2024 14:13:29 GMT</pubDate></item><item><title><![CDATA[Reply to Inflation reveal on Wed, 06 Mar 2024 03:14:45 GMT]]></title><description><![CDATA[<p dir="auto">Hi tie-version,</p>
<p dir="auto">This example has this option but has some limitations, such as shadows.<br />
<a href="/assets/uploads/files/1709694883936-cv4_2024_drs_24_rsbv_01.c4d">CV4_2024_drs_24_RSbv_01.c4d</a></p>
<p dir="auto">I have no idea what you need to have in the scene.<br />
https://help.maxon.net/c4d/2024/en-us/Default.htm#<em>REDSHIFT</em>/html/Ray+Switch.html?TocPath=Node%2520Editor%257CRedshift%2520Nodes%257CRedshift%2520Utility%2520Nodes%257CSwitch%2520Nodes%257C_____1</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3647</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3647</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 06 Mar 2024 03:14:45 GMT</pubDate></item><item><title><![CDATA[Reply to Inflation reveal on Mon, 04 Mar 2024 19:04:15 GMT]]></title><description><![CDATA[<p dir="auto">Hi tie-version,</p>
<p dir="auto">The simplest way would be to render a sequence without anything and then overlap that sequence with the inflating object.</p>
<p dir="auto">The transition from no object to the start of the inflating object can be done in many ways. Perhaps even using a mask produced with the inflating object, like a gradient moving across, or a noise turning from black to white, a mix of those.</p>
<p dir="auto">The advantage is that you can time the transition later instead of rendering it new. However, any secondary ray the object produces is also part of the transition, such as shadows, reflections, etc.</p>
<p dir="auto">If you have more details on how that should show up, please share.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3631</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3631</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Mon, 04 Mar 2024 19:04:15 GMT</pubDate></item></channel></rss>
