<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Attach Object to Alembic Simulation animation]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have created a simulation inflation animation, which I have baked down to an alembic, and then added to a morph to give me control over the animation.</p>
<p dir="auto">Now I have a new problem.</p>
<p dir="auto">The asset that is inflating is a Pool Inflatable, and the client would like the animation to feature handles and the valve moving with the inflation.<br />
Is there a way to bind them to the animation at this stage of the process? or will I need to remake everything?</p>
<p dir="auto">Thanks In advance</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/1053/attach-object-to-alembic-simulation-animation</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 11:17:16 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/1053.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Mar 2024 17:11:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Attach Object to Alembic Simulation animation on Mon, 25 Mar 2024 16:44:44 GMT]]></title><description><![CDATA[<p dir="auto">Hi tie-version,</p>
<p dir="auto">Thanks for updating your question.</p>
<p dir="auto">A solid handle is not an option to apply on an Alembic ballon simulation, as the handle would influence the initial results before the baking into Alembic.</p>
<p dir="auto">With all that said, here is an idea to get close.<br />
https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2024_PROJECTS_DRS/20240325_CV4_2024_drs_24_SIpp_21.zip</p>
<p dir="auto"><img src="/assets/uploads/files/1711385082519-screenshot-2024-03-25-at-9.43.50-am-resized.jpg" alt="Screenshot 2024-03-25 at 9.43.50 AM.jpg" class=" img-responsive img-markdown" /></p>
]]></description><link>https://cineversity.forums.maxon.net/post/3817</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3817</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Mon, 25 Mar 2024 16:44:44 GMT</pubDate></item><item><title><![CDATA[Reply to Attach Object to Alembic Simulation animation on Mon, 25 Mar 2024 15:42:57 GMT]]></title><description><![CDATA[<p dir="auto">Never mind on the seam effect. The surface tool was perfect.<br />
I will continue to look at the handle effect. But thank you again for your help.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3816</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3816</guid><dc:creator><![CDATA[tie-version]]></dc:creator><pubDate>Mon, 25 Mar 2024 15:42:57 GMT</pubDate></item><item><title><![CDATA[Reply to Attach Object to Alembic Simulation animation on Mon, 25 Mar 2024 15:36:49 GMT]]></title><description><![CDATA[<p dir="auto">This is really interesting stuff.<br />
The handles are solid ones, so I might need to look at how they can be solid using the same tool.</p>
<p dir="auto">In addition for the inflatable. In your opinion, what is the best way to achieve the thin seem effect that appears at the edge of pool inflatables? I feel like maybe an extrude, then use fields.<br />
But I imagine this is something that needed to be added in the first stages of the process <img src="https://cineversity.forums.maxon.net/assets/plugins/nodebb-plugin-emoji/emoji/twemoji2/1f604.png?v=7a11b27qclj" class="not-responsive emoji emoji-twemoji2 emoji--smile" title=":smile:" alt="😄" /></p>
<p dir="auto"><img src="/assets/uploads/files/1711380929607-977c1ca4-c86d-4def-9969-077fe1f00d1c-image-resized.png" alt="image.png" class=" img-responsive img-markdown" /></p>
]]></description><link>https://cineversity.forums.maxon.net/post/3815</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3815</guid><dc:creator><![CDATA[tie-version]]></dc:creator><pubDate>Mon, 25 Mar 2024 15:36:49 GMT</pubDate></item><item><title><![CDATA[Reply to Attach Object to Alembic Simulation animation on Fri, 22 Mar 2024 21:13:28 GMT]]></title><description><![CDATA[<p dir="auto">P.S.: Here are some options for elements on an editable abc file.</p>
<p dir="auto">To see how it "connects" with the abc balloon, I have installed a "spy cam".</p>
<p dir="auto">https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2024_PROJECTS_DRS/20240322_CV4_2024_drs_24_SIpp_11.zip</p>
<p dir="auto">Post-simulation changes are not working as simulated from the start, just to point out the obvious. However, closer to deadlines, I know that kind of stuff slips sometimes.</p>
<p dir="auto">As a side note:<br />
There might be an idea to use the Polygon Normal, but that is a single vector only, a simple direction only, which has no idea about the rotation around the Normal axis itself. Hence why I don't use it here.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3794</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3794</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Fri, 22 Mar 2024 21:13:28 GMT</pubDate></item><item><title><![CDATA[Reply to Attach Object to Alembic Simulation animation on Fri, 22 Mar 2024 21:01:56 GMT]]></title><description><![CDATA[<p dir="auto">Hi tie-version,</p>
<p dir="auto">I know you can see your object and have a clear idea of the new parts you need to add to it.</p>
<p dir="auto">I don't, and in my mind, I can see many possible ways about their shape, for example.</p>
<p dir="auto">The problem with inflating is that it requires simulation first, meaning the surface changes drastically.</p>
<p dir="auto">Here is an example of what I have in mind, and yes, that looks cartoony, but I wanted to demo it clearly:<br />
https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2024_PROJECTS_DRS/20240322_CV4_2024_drs_24_SIpp_01.zip</p>
<p dir="auto">For example, are the handles flat bands or solid rubber handles like on rafting boats?</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3793</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3793</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Fri, 22 Mar 2024 21:01:56 GMT</pubDate></item></channel></rss>
