<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Color for intersections]]></title><description><![CDATA[<p dir="auto">Hello<br />
I'm trying to achieve an effect where colors "change" when two surfaces overlap.  It is a bit like the effect you get when you take three circles of different colors and <img src="http://creativity103.com/collections/Graphic/subtractive_colours.jpg" alt="the intersections are an &quot;addition&quot; of the colors" class=" img-responsive img-markdown" />.</p>
<p dir="auto">I have two extruded circles in C4d and I am applying different textures to the cap and the extrusion.<br />
I'd like to have the color combination effect happen only on the caps when they overlap.</p>
<p dir="auto">I know this would normally be a blend mode, which I don't think is possible with two separate textures on two separate 3d objects, but maybe there is some technique that could be used for this?  Lighting maybe?</p>
<p dir="auto">Here is my current file<br />
https://www.dropbox.com/scl/fi/sikex997y5yf4bknl19hi/CylinderIntersection.c4d?rlkey=x3wfnylvi0mvk22il9qhy69db&amp;dl=0</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/1130/color-for-intersections</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 21:18:21 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/1130.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 30 Apr 2024 20:03:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Color for intersections on Wed, 01 May 2024 20:26:24 GMT]]></title><description><![CDATA[<p dir="auto">You're very welcome, AlexC.</p>
<p dir="auto">If images or video are projected on these three parts, while the middle material contains both resources, the illusion should work nicely.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4069</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4069</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 01 May 2024 20:26:24 GMT</pubDate></item><item><title><![CDATA[Reply to Color for intersections on Wed, 01 May 2024 09:18:02 GMT]]></title><description><![CDATA[<p dir="auto">So smart!  Thanks Sassi, that is absolutely perfect, procedural and clean.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4064</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4064</guid><dc:creator><![CDATA[AlexC]]></dc:creator><pubDate>Wed, 01 May 2024 09:18:02 GMT</pubDate></item><item><title><![CDATA[Reply to Color for intersections on Tue, 30 Apr 2024 21:26:18 GMT]]></title><description><![CDATA[<p dir="auto">Hi AlexC,</p>
<p dir="auto">Thanks for the file and for using Dropbox.</p>
<p dir="auto">Here is your file back.<br />
<a href="/assets/uploads/files/1714512376052-cv4_2024_drs_24_anis_11.c4d">CV4_2024_drs_24_ANis_11.c4d</a></p>
<p dir="auto">Please let me know if that works for you.</p>
<p dir="auto">My best wishes for your project</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4059</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4059</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Tue, 30 Apr 2024 21:26:18 GMT</pubDate></item></channel></rss>
