<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Step Files]]></title><description><![CDATA[<p dir="auto">I've received several Step files from the same source where some open just fine and others don't.  Size seems to be the issue.  The larger one I've let alone to open for several hours with no luck. Is there a size limit C4D has for Step files?  The ones above 250mgs seem to be an issue.  I've downloaded a trial of rhino and got them to open there but what to do then is the issue.  If  I resave as Step they still won't open in C4D.  If I make FBXs they become ridiculously heavy.</p>
<p dir="auto">Any thoughts?</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/1149/step-files</link><generator>RSS for Node</generator><lastBuildDate>Fri, 07 Aug 2026 11:13:09 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/1149.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 May 2024 17:07:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Step Files on Mon, 20 May 2024 16:52:44 GMT]]></title><description><![CDATA[<p dir="auto">Hi Tom,</p>
<p dir="auto">The first idea is to check if the computer is running out of memory.</p>
<p dir="auto">Anyway, please check with support, as crashes should not happen, and that needs to go to support. Thanks for considering it. I hope that can be solved for you quickly.<br />
https://www.maxon.net/en/support-center</p>
<p dir="auto">I'm sorry that you have to endure this.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4194</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4194</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Mon, 20 May 2024 16:52:44 GMT</pubDate></item><item><title><![CDATA[Reply to Step Files on Mon, 20 May 2024 13:52:25 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I am looking into this further because I foresee a fair amount of step files in my future. I'm working with seven step files that make up a machine. When I import one file with default settings, except for I turn off UVs, Normals and layers. and it imports in 22 minutes.  When I use best practices with Normals and Uvs and Combine  set  to topology, scale based tessellation, it crashes C4D after 55 minutes while processes UVs.  That's why I tried it with UVs  off.  When it crashes the Status bar says it's 93% thru processing UVs, and it's happened several times at that point.<br />
Any thoughts would be helpful,<br />
Tom</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4192</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4192</guid><dc:creator><![CDATA[Gliserman]]></dc:creator><pubDate>Mon, 20 May 2024 13:52:25 GMT</pubDate></item><item><title><![CDATA[Reply to Step Files on Wed, 15 May 2024 20:15:32 GMT]]></title><description><![CDATA[<p dir="auto">Hi Gliserman,</p>
<p dir="auto">Please have a look here (Short intro)<br />
https://www.cineversity.com/vidplaytut/c4d_r20_import_catia_step_iges_solidworks_jt_cad_files_in_cinema_4d</p>
<p dir="auto">The angles are the easiest, perhaps going as high as 120º (turning a full circle into a triangle), but it always depends<br />
For example, when you set the length, the data inside the file will be set based on its size and outcome; hence, it is relative. I do not know what is in your file.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4149</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4149</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 15 May 2024 20:15:32 GMT</pubDate></item><item><title><![CDATA[Reply to Step Files on Wed, 15 May 2024 19:59:32 GMT]]></title><description><![CDATA[<p dir="auto">Could you give me settings that would normally open a complex step file?<br />
Thanks</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4148</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4148</guid><dc:creator><![CDATA[Gliserman]]></dc:creator><pubDate>Wed, 15 May 2024 19:59:32 GMT</pubDate></item><item><title><![CDATA[Reply to Step Files on Wed, 15 May 2024 19:11:19 GMT]]></title><description><![CDATA[<p dir="auto">Hi wait-channel,</p>
<p dir="auto">The import of step files requires setting up some quality-changing parameters.<br />
https://help.maxon.net/c4d/2024/en-us/Default.htm#html/FSTEPIMPORT-CADIMPORT_GRP_TESSELATION.html?TocPath=CAD%2520Import%257CSTEP%2520Import%2520Settings%257C_____3</p>
<p dir="auto">In a nutshell, when a curved object is present in the file, it is stored as a "circle shape formula." When opened in a polygon-based polygon application like Cinema 4D, those "formula-based shapes" need to generate polygons. The angle parameter enters the game. The smaller the angle, the more polygons will be produced during the import.</p>
<p dir="auto">It makes no sense to compare it with another polygon-based app with different default settings or with an application that works natively with STEP, as it will read the "formula-based" shapes as such.</p>
<p dir="auto">Often those files contain a lot of little parts (like bolts/screws) that are pretty much invisible compared to the main object, but based on those default settings, they can create an enormous amount of polygons with no visual advantage at all.</p>
<p dir="auto">Importing these files often means starting with large values and producing a small result. Then, evaluate the results and adjust accordingly.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4146</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4146</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 15 May 2024 19:11:19 GMT</pubDate></item></channel></rss>
