<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Blend Numbers with cloner]]></title><description><![CDATA[<p dir="auto">Hi <img src="https://cineversity.forums.maxon.net/assets/plugins/nodebb-plugin-emoji/emoji/twemoji2/1f642.png?v=7a11b27qclj" class="not-responsive emoji emoji-twemoji2 emoji--slightly_smiling_face" title=":)" alt="🙂" /> In a cloner i can use the Blend mode between 0 and 100, i can do the same between 0% and 100%?<img src="/assets/uploads/files/1717692697253-df.jpg" alt="df.JPG" class=" img-responsive img-markdown" /></p>
]]></description><link>https://cineversity.forums.maxon.net/topic/1189/blend-numbers-with-cloner</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 00:43:06 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/1189.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 06 Jun 2024 16:51:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Blend Numbers with cloner on Wed, 12 Jun 2024 16:32:16 GMT]]></title><description><![CDATA[<p dir="auto">Sounds good, Pitchi.</p>
<p dir="auto">Thank you very much for the feedback</p>
<p dir="auto">Cheers</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4400</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4400</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 12 Jun 2024 16:32:16 GMT</pubDate></item><item><title><![CDATA[Reply to Blend Numbers with cloner on Wed, 12 Jun 2024 12:28:08 GMT]]></title><description><![CDATA[<p dir="auto">Okay <img src="https://cineversity.forums.maxon.net/assets/plugins/nodebb-plugin-emoji/emoji/twemoji2/1f642.png?v=7a11b27qclj" class="not-responsive emoji emoji-twemoji2 emoji--slightly_smiling_face" title=":)" alt="🙂" /> thanks you <img src="https://cineversity.forums.maxon.net/assets/plugins/nodebb-plugin-emoji/emoji/twemoji2/1f604.png?v=7a11b27qclj" class="not-responsive emoji emoji-twemoji2 emoji--smile" title=":D" alt="😄" /></p>
]]></description><link>https://cineversity.forums.maxon.net/post/4396</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4396</guid><dc:creator><![CDATA[Pitchi]]></dc:creator><pubDate>Wed, 12 Jun 2024 12:28:08 GMT</pubDate></item><item><title><![CDATA[Reply to Blend Numbers with cloner on Thu, 06 Jun 2024 23:29:04 GMT]]></title><description><![CDATA[<p dir="auto">Hi Pitchi,</p>
<p dir="auto">Please have a look here:<br />
https://www.cineversity.com/vidplaytut/controlling_the_numbers_using_xpresso</p>
<p dir="auto">The problem is typically that even if the numbers are truncated (XPresso&gt; Formula node), the interpolation is done after the "trunc(a)" formula inside the Cloner (outside XPresso), and then you get the decimals.</p>
<p dir="auto">My way of getting fast and easy adjustable fixed values is based on producing 101 of them first (101 = 0 to 100) and using these 101 as child objects under a new Cloner, while a linear field defines the results.<br />
Please have a look here:</p>
<p dir="auto">https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2024_PROJECTS_DRS/20240606_CV4_2024_drs_24_XPpn_01.c4d.zip</p>
<p dir="auto">The Linear field can be adjusted with a Spline interface, so any kind of %-progress can be dialed in.</p>
<p dir="auto">I have placed the "prep file" into a layer and have hidden them there.<br />
Let me know if there are any questions, I'm happy to look into it</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4346</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4346</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Thu, 06 Jun 2024 23:29:04 GMT</pubDate></item></channel></rss>
