<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Dynamic Simulations Kill MY Computer]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I'm having a really really frustrating time with simulations.<br />
I use cinema 4d mostly for modelling and technical instruction animations, and don't have all that much use for dynamic simulations. BUT, the odd times that I do need it, I find it impossible to work with. The most seemingly simple things that the tutorials on YouTube show that will play in nearly real time for them ( Rope, connector, balloon, gravity, turbulence etc etc) shuts my computer down instantaneously. Even in the simplest scene.<br />
My workstation is a couple of years old, but pretty well stocked with a Intel i9-9900K CPU 3.60 GHz, 64 gigs ram and 2 RTX A4000 cards.<br />
After setting a simulation, I push play, only to have the thing freeze for 4 minutes then proceed to go 1 frame every 30 seconds or something. I cant stop it, I cant click anything and then I have to crash it with the task manager.<br />
Very frustrating. Is there a setting or something Im missing? I get collision limit exceeded messages sporadically too, but after setting it from GPU to CPU like suggested, its worse...<br />
Any ideas?<br />
Thanks in advance<br />
Simon</p>
<p dir="auto">EDIT: Seems the simulations aren't the only thing going sideways. Vibration tag is killing it now as well. New updates yesterday..... hmmmm....</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/1199/dynamic-simulations-kill-my-computer</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 01:02:17 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/1199.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Jun 2024 13:15:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Dynamic Simulations Kill MY Computer on Thu, 13 Jun 2024 05:40:57 GMT]]></title><description><![CDATA[<p dir="auto">Fingers crossed it doesn't persist, Simon.</p>
<p dir="auto">Otherwise, I hope the tech support can help you.</p>
<p dir="auto">One more idea: you can also check Cinebench to see how your setup performed.</p>
<p dir="auto">https://www.maxon.net/en/downloads/cinebench-2024-downloads</p>
<p dir="auto">My best wishes</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4405</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4405</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Thu, 13 Jun 2024 05:40:57 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic Simulations Kill MY Computer on Thu, 13 Jun 2024 05:35:37 GMT]]></title><description><![CDATA[<p dir="auto">Cheers, Ill get on it if this is persisting...<br />
MfG Simon</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4404</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4404</guid><dc:creator><![CDATA[Rough1]]></dc:creator><pubDate>Thu, 13 Jun 2024 05:35:37 GMT</pubDate></item><item><title><![CDATA[Reply to Dynamic Simulations Kill MY Computer on Thu, 13 Jun 2024 05:41:10 GMT]]></title><description><![CDATA[<p dir="auto">Hi Simon,</p>
<p dir="auto">I assume that would be a question for the tech support. based on your "edit" I would think you gave a lot of pointers to check with tech support.<br />
https://www.maxon.net/en/support-center</p>
<p dir="auto">The exact URL also has an entry for "Requirements".</p>
<p dir="auto">The Graphics Cards perform increasingly complex calculations, and this might work fine in your setup.<br />
But certain things need to be pulled back into the CPU, and there is often the bottleneck. moving data around.<br />
I do not have a complete list when and how those slow-down combinations happen. I can't answer that.</p>
<p dir="auto">I also have no idea what some presenters use to run it, so I hope tech support can tell you more about your specific setup. I do not do anything hardware-related here.</p>
<p dir="auto">My tip, try to cache the scene and see if that improves everything.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4401</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4401</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Thu, 13 Jun 2024 05:41:10 GMT</pubDate></item></channel></rss>
