<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Scatter Clones based on Vertex Color]]></title><description><![CDATA[<p dir="auto">Splitting a post that was added to a different theme.<br />
Please only one subject per thread. Thank you.</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/1263/scatter-clones-based-on-vertex-color</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Mar 2026 04:55:31 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/1263.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Jul 2024 21:25:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Scatter Clones based on Vertex Color on Tue, 30 Jul 2024 16:43:42 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the positive feedback, solid-honey.</p>
<p dir="auto">I'm glad it is working for your project.</p>
<p dir="auto">My best wishes.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4724</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4724</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Tue, 30 Jul 2024 16:43:42 GMT</pubDate></item><item><title><![CDATA[Reply to Scatter Clones based on Vertex Color on Tue, 30 Jul 2024 13:09:45 GMT]]></title><description><![CDATA[<p dir="auto">This worked perfectly! Thank you so much!</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4723</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4723</guid><dc:creator><![CDATA[solid-honey]]></dc:creator><pubDate>Tue, 30 Jul 2024 13:09:45 GMT</pubDate></item><item><title><![CDATA[Reply to Scatter Clones based on Vertex Color on Fri, 26 Jul 2024 21:51:38 GMT]]></title><description><![CDATA[<p dir="auto">Hi solid-honey,</p>
<p dir="auto">To my knowledge, the Color Vertex Tag is not very useful here if painted.</p>
<p dir="auto">If you can convert it:<br />
https://help.maxon.net/c4d/2024/en-us/Default.htm#html/55293.html<br />
Then it is easy; have a look here; I have set up the example from a Color Vertex Map. If only Black and white, why not use directly a Vertex Map?<br />
Perhaps you share a little bit more.</p>
<p dir="auto">In any other combinations, the results (if at all) are not stable.</p>
<p dir="auto"><a href="/assets/uploads/files/1722030696513-cv4_2024_drs_24_mgvc_01.c4d">CV4_2024_drs_24_MGvc_01.c4d</a></p>
]]></description><link>https://cineversity.forums.maxon.net/post/4708</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4708</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Fri, 26 Jul 2024 21:51:38 GMT</pubDate></item><item><title><![CDATA[Reply to Scatter Clones based on Vertex Color on Fri, 26 Jul 2024 19:59:53 GMT]]></title><description><![CDATA[<p dir="auto">Hello. Is there a way to scatter objects using the vertex color tag? For example, I have the main object which has a vertex color tag (black and white values) and then I want to scatter smaller objects onto the main object using the vertex color tag. I want to scatter them where the white areas are painted.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4705</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4705</guid><dc:creator><![CDATA[solid-honey]]></dc:creator><pubDate>Fri, 26 Jul 2024 19:59:53 GMT</pubDate></item></channel></rss>
