<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Getting Weird Artifacts When Rendering]]></title><description><![CDATA[<p dir="auto">As you can see by the render, I sometimes get these weird white lines when I render. I was not getting them, but now I am. I am using the toon shader and Redshift.</p>
<p dir="auto">https://www.dropbox.com/scl/fo/cn9bzkg3cg2m90jug1nxd/APBi16L94JIvMO_48xKLqkQ?rlkey=sh3816bndge2p24wzryannz4n&amp;dl=0</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/1266/getting-weird-artifacts-when-rendering</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 20:19:29 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/1266.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 30 Jul 2024 12:18:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Getting Weird Artifacts When Rendering on Tue, 30 Jul 2024 17:03:09 GMT]]></title><description><![CDATA[<p dir="auto">Hi skin-tone,</p>
<p dir="auto">Thanks for using Dropbox. Please do not use the Link-code-setup, I had asked IT to shut it off, as everyone needs to see what link is clicked. Anything else is not secure for anyone to use. I have changed it, in case you wonder.</p>
<p dir="auto">What is going on in the scene is not in the images. Before you share more images, please don't. What I need is a project file. So I can see the material setup, the light, the camera settings, etc.</p>
<p dir="auto">If the scene itself can't be shared, I'm sure it should be simple to place a few cubes into the scene instead and share it if it produces the same problems. I'm happy to explore it.</p>
<p dir="auto">Thanks for the dropbox use.</p>
<p dir="auto">If you can do that for various reasons, as this is a semi-public forum, please check with tech support.<br />
https://www.maxon.net/en/support-center</p>
<p dir="auto">Either way, I hope it is solved quickly for you.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4725</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4725</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Tue, 30 Jul 2024 17:03:09 GMT</pubDate></item></channel></rss>
