<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RedShift ignores particles based objects in render sequence]]></title><description><![CDATA[<p dir="auto">In this scene, I am creating petals using emitters following and colliding with some objects, until suddenly, a week ago, I noticed that my render using redshift, ignores completely the main particles emitter randomly (example :frame 3 in my scene), even if:</p>
<p dir="auto">1- it is cached<br />
2-it is seen in the viewport<br />
2- it is renderable using Redshift IPR but not renderable using Picture Viewer nor as a saved picture<br />
3-It is renderable using standard and physical renderer</p>
<p dir="auto">When I bake the mograph that uses the particle group to Alembic, it works better but I have some petals exploded into small pieces like the picture shown (example: frame 4 in my scene)</p>
<p dir="auto">I changed the scene, debugged on and off, motion blur, bokeh, changing particles objects inside mograph, starting a new scene using the same setup...etc.</p>
<p dir="auto">Help is appreciated</p>
<p dir="auto">https://we.tl/t-hAMa81w1CN</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/1272/redshift-ignores-particles-based-objects-in-render-sequence</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 18:09:48 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/1272.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 04 Aug 2024 16:57:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RedShift ignores particles based objects in render sequence on Sun, 04 Aug 2024 18:13:14 GMT]]></title><description><![CDATA[<p dir="auto">Have a great Sunday as well, resort-sand.</p>
<p dir="auto">Thank you very much for your feedback. <img src="https://cineversity.forums.maxon.net/assets/plugins/nodebb-plugin-emoji/emoji/twemoji2/1f642.png?v=7a11b27qclj" class="not-responsive emoji emoji-twemoji2 emoji--slightly_smiling_face" title=":-)" alt="🙂" /></p>
<p dir="auto">My best wishes for your project.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4754</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4754</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Sun, 04 Aug 2024 18:13:14 GMT</pubDate></item><item><title><![CDATA[Reply to RedShift ignores particles based objects in render sequence on Sun, 04 Aug 2024 18:06:33 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Dr. The alembic files were not very important to reproduce the bug, actually I am testing it now by putting a scatter object between the Particle Group and the Mograph object and the early tests show no render bugs.<br />
There is always a scatter object that solves an issue inside c4d<br />
I appreciate once again your quick solution, even on a Sunday</p>
<p dir="auto">Have a great day</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4753</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4753</guid><dc:creator><![CDATA[resort-sand]]></dc:creator><pubDate>Sun, 04 Aug 2024 18:06:33 GMT</pubDate></item><item><title><![CDATA[Reply to RedShift ignores particles based objects in render sequence on Sun, 04 Aug 2024 17:51:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi resort-sand,</p>
<p dir="auto">Thanks for using Wetransfer.</p>
<p dir="auto">I checked the file; the abc file was not part of the package. Some images were not part of the download.</p>
<p dir="auto">I cached it new as I saw that you had set the time to "F =-150". I increased the project time first to 0-300 (250 would be fine, but why not have some wiggle room).</p>
<p dir="auto">Then I set the time offset as well to -150</p>
<p dir="auto">After setting the project time back to 0-100.</p>
<p dir="auto">It rendered in the RS but not in the Picture Viewer. So I added a Matrix between the particle Group and the Cloner.</p>
<p dir="auto">https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2024_PROJECTS_DRS/20240804_CV4_2024_drs_24_RSpa_01.zip</p>
<p dir="auto">I checked and all renders fine here both render options (RS and PV).</p>
<p dir="auto">Is this working for you? Missing your abc-file, introduced some uncertainty here.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4752</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4752</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Sun, 04 Aug 2024 17:51:51 GMT</pubDate></item></channel></rss>
