<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cinema 4D redshift textures lost in “ramdisk”]]></title><description><![CDATA[<p dir="auto">Thousands of textures from hundreds of folders trying to load in from ram. The file names are slightly different making re-linking impossible.</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/1283/cinema-4d-redshift-textures-lost-in-ramdisk</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Mar 2026 16:31:37 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/1283.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 18 Aug 2024 10:19:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cinema 4D redshift textures lost in “ramdisk” on Sun, 18 Aug 2024 18:29:36 GMT]]></title><description><![CDATA[<p dir="auto">Good Morning, funeral-reflection,</p>
<p dir="auto">I'm struggling with the term ramdisk in connection with Redshift 3D and textures; I haven't heard it in nearly two decades. It was a virtual disc on a Mac based on a defined Volume in RAM back then. The Manual of Redshift 3D does not provide this term at all. So, I might miss something here.<br />
.</p>
<p dir="auto">I would surely like to help, but I'm unsure what to do with this short text.<br />
You gave more information elsewhere, as far as my Google search tells me.</p>
<p dir="auto">I try to not answer from memory, as things might have changed, so I love to explore it carefully, as you can see below: (Sorry for the longer text)<br />
.</p>
<p dir="auto">I have recreated the names as you had it "elsewhere" posted, if that is the same you:  I would not place periods nor only sequence numbers as identifiers in otherwise unrelated files. In short, that is nothing where I have any experience with.</p>
<p dir="auto">Anyway, I placed those in a folder, connected a few via a Texture Node, and applied them to different objects. After that, I renamed the folder holding the Files and placed that folder into a new folder. (Which should be sufficient chaos for any system.)</p>
<p dir="auto">I went to the Main Menu&gt;Redshift&gt; RS Asset Manager. Used the "Select Missing Files"</p>
<p dir="auto">Then I selected only the SSD icon, and all files from that drive were instantly re-connected</p>
<p dir="auto">.<br />
I did this again: I created a new folder and then placed any content in it. This time I checked the Main Menu&gt; Window&gt; Project Asset Manager.</p>
<p dir="auto">Also, here, Select missing items, the Relink, and click only on the SDD holding the items. All instantly connected.</p>
OK, one more: Using the Preferences&gt; Files&gt; File Assets: Path</p>
<p dir="auto">Here, I can click them on or off, and the Files are connected (on) and then not (off)</p>
<p dir="auto">I hope that helps, as I surely know how annoying any work is that does not increase the quality of a project.</p>
<p dir="auto">.<img src="/assets/uploads/files/1724005717945-screenshot-2024-08-18-at-11.18.47-am-resized.jpg" alt="Screenshot 2024-08-18 at 11.18.47 AM.jpg" class=" img-responsive img-markdown" /><br />
Have a nice Sunday and my best wishes for the project.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/4823</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/4823</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Sun, 18 Aug 2024 18:29:36 GMT</pubDate></item></channel></rss>
