<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Objects falling through floor with dynamic placement tool]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">Does the dynamic placement tool not work with a floor object? I've been arranging some objects and it has worked as expected, objects not passing through each other but not the floor, they just fall right through it. For now I've just put a simple cube under the floor and that has worked but shouldn't it work with a floor?</p>
<p dir="auto">Kind Regards<br />
David</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/1369/objects-falling-through-floor-with-dynamic-placement-tool</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 20:04:39 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/1369.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Sep 2024 09:20:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Objects falling through floor with dynamic placement tool on Sat, 28 Sep 2024 03:03:09 GMT]]></title><description><![CDATA[<p dir="auto">Hi David,</p>
<p dir="auto">Yes, I know that feeling only too well. I try to learn each month a new app or at least a major update. This feeling of running against the wall is a constant. It helps me never to think that my muscle memory is all there is with the things I do often.</p>
<p dir="auto">Please feel always free to ask, and those feelings will get into the background, at least with one app at a time <img src="https://cineversity.forums.maxon.net/assets/plugins/nodebb-plugin-emoji/emoji/twemoji2/1f609.png?v=7a11b27qclj" class="not-responsive emoji emoji-twemoji2 emoji--wink" title=";-)" alt="😉" /></p>
<p dir="auto">Cheers</p>
]]></description><link>https://cineversity.forums.maxon.net/post/5205</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/5205</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Sat, 28 Sep 2024 03:03:09 GMT</pubDate></item><item><title><![CDATA[Reply to Objects falling through floor with dynamic placement tool on Fri, 27 Sep 2024 23:57:00 GMT]]></title><description><![CDATA[<p dir="auto">Hi Dr Sassi,</p>
<p dir="auto">Aah thanks so much for the confirmation, I thought I was being an idiot <img src="https://cineversity.forums.maxon.net/assets/plugins/nodebb-plugin-emoji/emoji/twemoji2/1f602.png?v=7a11b27qclj" class="not-responsive emoji emoji-twemoji2 emoji--joy" title=":joy:" alt="😂" /> Yes the cube I put underneath worked a treat <img src="https://cineversity.forums.maxon.net/assets/plugins/nodebb-plugin-emoji/emoji/twemoji2/1f44d.png?v=7a11b27qclj" class="not-responsive emoji emoji-twemoji2 emoji--+1" title=":+1:" alt="👍" /></p>
David</p>
]]></description><link>https://cineversity.forums.maxon.net/post/5203</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/5203</guid><dc:creator><![CDATA[DaveMDarcy]]></dc:creator><pubDate>Fri, 27 Sep 2024 23:57:00 GMT</pubDate></item><item><title><![CDATA[Reply to Objects falling through floor with dynamic placement tool on Fri, 27 Sep 2024 19:32:45 GMT]]></title><description><![CDATA[<p dir="auto">Hi David,</p>
<p dir="auto">I can confirm that it falls right through it.</p>
<p dir="auto">It is not "really" an object (you can't make it editable, for example, or deform it), and while it is no longer in use in Redshift 3D render setup, I have very little hope that a tech-support request would help here.</p>
<p dir="auto">You might try it if you don't mind the time:<br />
https://www.maxon.net/en/support-center</p>
<p dir="auto">However, your use of an added object supporting the function is surely a winning strategy.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/5198</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/5198</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Fri, 27 Sep 2024 19:32:45 GMT</pubDate></item></channel></rss>
