<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cloth simulation]]></title><description><![CDATA[<p dir="auto">Hi! I’m new to cinema 4D and I want to make a basketball jersey spinning for work with a cloth simulation.</p>
<p dir="auto">For some reason, when I try to rotate it with the simulation, it doesn’t follow the rotation I animated before and instead just sits and ripples a lot.</p>
<p dir="auto">How can I get it to follow the rotation animation and what settings would be best to simulate a jersey material?</p>
<p dir="auto">Thank you so much in advance!!</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/1521/cloth-simulation</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 11:40:16 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/1521.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Dec 2024 15:11:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cloth simulation on Sat, 14 Dec 2024 04:58:28 GMT]]></title><description><![CDATA[<p dir="auto">Hi ground-water,</p>
<p dir="auto">Thanks for the file and the Google Cloud use; this is perfect.</p>
<p dir="auto">Here is a little suggestion.<br />
https://projectfiles.maxon.net/Cineversity_Forum_Support/2024_PROJECTS_DRS/20241213_CV4_2025_drs_24_SIbs_01c4d.zip<br />
This file needs to be in your Project folder, unzipped.</p>
<p dir="auto"><img src="/assets/uploads/files/1734152306905-screenshot-2024-12-13-at-8.56.45-pm.jpg" alt="Screenshot 2024-12-13 at 8.56.45 PM.jpg" class=" img-responsive img-markdown" /></p>
<p dir="auto">The shirt was built with volume, which doesn't help,  so I made a copy and took the inside out. The Cloth Surface will replace the thickness.<br />
The mesh was rather dense, so I Remeshed it. Hence, the texture is off, but let us focus on the motion first. This is art direction, and I have no idea how you would like to have it.<br />
The Puppet is a bad Collider, hence I smoothed it with the Volume workflow. Otherwise, the two shoulder "balls" shape the shirt. (or was that intentional?)</p>
<p dir="auto">I have decreased the Gravity and the Mass of the shirt. With a Mass of 1, that shirt would be 1kg per 1000cc and normal Gravity. With the modeled initial double-sided. The typical air in the fabric is not acknowledged, etc.</p>
<p dir="auto">Cache it first.</p>
<p dir="auto">Let me know what you think about it.</p>
<p dir="auto">Enjoy your weekend.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/5948</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/5948</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Sat, 14 Dec 2024 04:58:28 GMT</pubDate></item><item><title><![CDATA[Reply to Cloth simulation on Fri, 13 Dec 2024 22:59:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://cineversity.forums.maxon.net/uid/13">@Dr-Sassi</a> thank you for the quick reply!<br />
Sorry it took me a while to test, a lot of stuff came up in my personal life.</p>
<p dir="auto">I tried copying your forces but the cloth seems to just stretch and fall off.<br />
Is it the gravity in the scene? What am I missing?<br />
Here is the file<br />
https://drive.google.com/drive/folders/1FtYXOiRjUckrdSaF6PaNyzZeTHbKtgh0?usp=sharing</p>
<p dir="auto">Sorry for the google link - it was too big to upload</p>
]]></description><link>https://cineversity.forums.maxon.net/post/5946</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/5946</guid><dc:creator><![CDATA[ground-water]]></dc:creator><pubDate>Fri, 13 Dec 2024 22:59:21 GMT</pubDate></item><item><title><![CDATA[Reply to Cloth simulation on Sun, 01 Dec 2024 22:55:42 GMT]]></title><description><![CDATA[<p dir="auto">Hi ground-water,</p>
<p dir="auto">Here is an example of direct driving connections. The finer the mesh, the more "soft" it will behave.</p>
<p dir="auto"><a href="/assets/uploads/files/1733093731796-cv4_2025_24_sijs_01.c4d">CV4_2025_24_SIjs_01.c4d</a></p>
<p dir="auto">Here is a show about several ideas and fabric<br />
https://www.youtube.com/watch?v=wix_9Gv-uBA</p>
]]></description><link>https://cineversity.forums.maxon.net/post/5779</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/5779</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Sun, 01 Dec 2024 22:55:42 GMT</pubDate></item></channel></rss>
