<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Noise in Renders]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">I am using Cinema 4d with Red Shift. My renders are coming out sort of grainy like there is noise applied to them. May be some GI setting? Any way to fix it?</p>
<p dir="auto">Ken</p>
<p dir="auto">detail of render</p>
<p dir="auto"><img src="/assets/uploads/files/1739933018615-example.jpg" alt="example.jpg" class=" img-responsive img-markdown" /></p>
]]></description><link>https://cineversity.forums.maxon.net/topic/1710/noise-in-renders</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 06:39:47 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/1710.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Feb 2025 02:48:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Noise in Renders on Thu, 20 Feb 2025 21:28:46 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the update, Ken.</p>
<p dir="auto">My best wishes</p>
]]></description><link>https://cineversity.forums.maxon.net/post/6592</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/6592</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Thu, 20 Feb 2025 21:28:46 GMT</pubDate></item><item><title><![CDATA[Reply to Noise in Renders on Thu, 20 Feb 2025 19:53:54 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the feedback. Turns out the sun disc was way to big. Not sure how that works, kinda stumbled on to it.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/6590</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/6590</guid><dc:creator><![CDATA[walk-hour]]></dc:creator><pubDate>Thu, 20 Feb 2025 19:53:54 GMT</pubDate></item><item><title><![CDATA[Reply to Noise in Renders on Wed, 19 Feb 2025 05:34:35 GMT]]></title><description><![CDATA[<p dir="auto">Hi Ken,</p>
<p dir="auto">Noise can have many sources; typically, it lacks information, AKA samples, which can result from different sources.<br />
https://www.youtube.com/live/L4riSkE7FwA?feature=shared&amp;t=3668<br />
This is the summary, but she tells the sequence in which to look at the source of noise. The timestamps will give you easy access to the sub-themes.</p>
<p dir="auto"><img src="/assets/uploads/files/1739943273368-screenshot-2025-02-18-at-7.48.30-pm-resized.jpg" alt="Screenshot 2025-02-18 at 7.48.30 PM.jpg" class=" img-responsive img-markdown" /></p>
<p dir="auto">In short: There are two main ways to avoid those, Noise reduction (part of the Redshift Package), or higher Sampling (smaller numbers).<br />
https://www.youtube.com/live/7vDm9wV9BcQ?feature=shared&amp;t=2734<br />
(Sorry for the Microphone picking up the table sounds.)</p>
<p dir="auto">This is a simple way, just higher Samples or Noise reduction, but perhaps it causes much longer render times, while other ways would be more efficient.<br />
This means checking what causes it.</p>
<p dir="auto">A good collection of this theme is here (documentation)<br />
https://help.maxon.net/c4d/2025/en-us/Default.htm#html/VPRSRENDERER-REDSHIFT_RENDERER_TAB_SAMPLING.html?TocPath=Render%2520Menu%257CRender%2520Setting%257CRedshift%2520Renderer%257C_____2</p>
<p dir="auto">A nice discussion about this is here:<br />
https://www.youtube.com/live/il2EHLxcchg?feature=shared&amp;t=858</p>
<p dir="auto">If you think it is GI, perhaps send some more rays out, but yes, that might be a simple answer. However, I hope the content above gave you enough for better results.</p>
<p dir="auto">I hope that helps.</p>
<p dir="auto">My best wishes for your project.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/6558</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/6558</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 19 Feb 2025 05:34:35 GMT</pubDate></item></channel></rss>
