<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Help] Setting up Objects for Correct Refractions]]></title><description><![CDATA[<p dir="auto"><a href="https://cineversity.maxon.net/tutorials/04-deep_dive_into_refractive_objects_-_correct_refractions">View Tutorial</a></p>
<ul>
<li>Other</li>
</ul>
]]></description><link>https://cineversity.forums.maxon.net/topic/178/help-setting-up-objects-for-correct-refractions</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 21:56:58 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/178.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Dec 2022 18:51:29 GMT</pubDate><ttl>60</ttl></channel></rss>
