<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Help] Simulating a Simple Marble Run Setup (1&#x2F;4)]]></title><description><![CDATA[<p dir="auto"><a href="https://cineversity.maxon.net/tutorials/simulating-a-simple-marble-run-setup-1-4-create-with-maxon">View Tutorial</a><br />
<strong>Tag:</strong> <a href="https://cineversity.maxon.net/learn?filter=All&amp;product=Cinema-4D">Cinema 4D | null</a></p>
<ul>
<li>Other</li>
</ul>
]]></description><link>https://cineversity.forums.maxon.net/topic/1832/help-simulating-a-simple-marble-run-setup-1-4</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 21:44:57 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/1832.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Apr 2025 11:54:00 GMT</pubDate><ttl>60</ttl></channel></rss>
