<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Help] Pick Up and Set Down Objects with the Parent Constraint]]></title><description><![CDATA[<p dir="auto"><a href="https://cineversity.maxon.net/tutorials/pick_up_and_set_down_objects_with_the_parent_constraint">View Tutorial</a><br />
<strong>Tag:</strong> <a href="https://cineversity.maxon.net/learn?filter=All&amp;product=Cinema-4D">Cinema 4D | null</a></p>
<ul>
<li>Other</li>
</ul>
]]></description><link>https://cineversity.forums.maxon.net/topic/1915/help-pick-up-and-set-down-objects-with-the-parent-constraint</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Nov 2026 09:56:28 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/1915.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Jun 2025 08:47:05 GMT</pubDate><ttl>60</ttl></channel></rss>
