<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Dynamic string that holds an ornament and swings in a realistic way.]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I’m using R25,121<br />
I’m trying to make a dynamic string that has an ornament attached at the end of it.<br />
Ideally I would like the whole set-up to be dynamic, meaning the torus at the end of the string and the ornament will react to one another, I have tried a tutorial that uses dynamic chains and I thought I could modify it to be a string (see DB link)<br />
It kinda works, but only when I reset the playhead back to 0 (see image link)<br />
https://www.dropbox.com/s/2a4bnfvtbabt782/Screen%20Shot%202022-12-22%20at%2010.09.21%20AM.png?dl=0<br />
I know in 2023 there is a new rope simulation included, but is this possible in R25?</p>
<p dir="auto">https://www.dropbox.com/s/mufgst8nbfp2qty/Dynamics%20chain%20rope%201.c4d.zip?dl=0</p>
<p dir="auto">Any suggestions would be very helpful!<br />
Thank you!</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/197/dynamic-string-that-holds-an-ornament-and-swings-in-a-realistic-way</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 10:21:26 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/197.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Jan 2023 16:47:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Dynamic string that holds an ornament and swings in a realistic way. on Wed, 04 Jan 2023 19:20:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi object-kind,|</p>
<p dir="auto">Please have a look here:<br />
https://www.dropbox.com/s/7ko3rk8kls50ph6/CV4_R25_drs_22_DYxc_01.c4d.zip?dl=0</p>
<p dir="auto">I have simplified the setup and replaced the cubes with a proxy chain element.</p>
<p dir="auto">There is usually an option to use a proxy object to have a more detailed model visible, but not used as the dynamic base.</p>
<p dir="auto">My suggestion here is either cache the solution and replace then the parts or use after caching the Matrix (or a new Cloner) object and use the cached dynamic to drive the detailed version.</p>
<p dir="auto">I have used the Ornament Sphere here as a Clone, while it is placed based on Cloner&gt; Sort and Plaineffector&gt; Modify Clones (driven by a MoGraph Selection.</p>
<p dir="auto">You might like to adjust the project Settings&gt; Dynamics&gt; Steps.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/210</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/210</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 04 Jan 2023 19:20:51 GMT</pubDate></item></channel></rss>
