<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Default material projection]]></title><description><![CDATA[<p dir="auto">Is it possible to set the default material projection to Cubic in stead of UVW Mapping and the Projection Display to Grid in stead of Simple when dropping materials to a polygon or primitive?</p>
<p dir="auto"><img src="/assets/uploads/files/1758014579156-scherm-afbeelding-2025-09-16-om-11.18.26-resized.jpg" alt="Scherm­afbeelding 2025-09-16 om 11.18.26.jpg" class=" img-responsive img-markdown" /></p>
]]></description><link>https://cineversity.forums.maxon.net/topic/2083/default-material-projection</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 10:41:55 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/2083.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Sep 2025 09:23:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Default material projection on Wed, 17 Sep 2025 17:28:41 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very much, Dutchbird.</p>
<p dir="auto">I miss this single default option as well.<br />
Very nice of you!</p>
<p dir="auto">Have a great day</p>
]]></description><link>https://cineversity.forums.maxon.net/post/8054</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/8054</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 17 Sep 2025 17:28:41 GMT</pubDate></item><item><title><![CDATA[Reply to Default material projection on Wed, 17 Sep 2025 14:53:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://cineversity.forums.maxon.net/uid/13">@Dr-Sassi</a> Done. Shared the Idea</p>
]]></description><link>https://cineversity.forums.maxon.net/post/8052</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/8052</guid><dc:creator><![CDATA[Dutchbird]]></dc:creator><pubDate>Wed, 17 Sep 2025 14:53:59 GMT</pubDate></item><item><title><![CDATA[Reply to Default material projection on Tue, 16 Sep 2025 17:40:50 GMT]]></title><description><![CDATA[<p dir="auto">Hi Dutchbird,</p>
<p dir="auto">With the introduction of the Preset System, the "Set as Default" for a single parameter was gone.</p>
<p dir="auto">Setting a Preset requires a step to set a desired state. Hence, there is zero advantage compared to setting the parameter manually and directly, given it is a pull-down menu entry. (Parameters are a little bit less work with it</p>
<p dir="auto">My suggestion, please support he re-introduction of the Set as Default (Single parameter) with an input to the "Share Your Idea"<br />
https://www.maxon.net/en/support-center</p>
<p dir="auto">I have done it, but it needs more "votes".</p>
<p dir="auto">Thank you</p>
]]></description><link>https://cineversity.forums.maxon.net/post/8045</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/8045</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Tue, 16 Sep 2025 17:40:50 GMT</pubDate></item></channel></rss>
