<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Redshift just shat itself suddenly]]></title><description><![CDATA[<p dir="auto">Shock, horror!</p>
<p dir="auto">Ive been adjusting a scene all day with the RS window open, not doing anything crazy, repositioning some lights when suddenly the RS renderview goes black. CRITICAL ERROR!</p>
<p dir="auto">Unresponsive, I restart C4D. Try to open the project and hit RS renderview again. Update Redshift to newest version. Boom, same error.  Has my GPU just fried?</p>
<p dir="auto">Heres the kicker. Open a different project. RS is working fine. Another. Fine.</p>
<p dir="auto">Open the same project, boom! error! remove a large tree.....working?...</p>
<p dir="auto">So im guessing its a memory issue? point is, I didnt change anything with the tree. And its been rendering it all day fine. Now, no. Any suggestions? Here is the log file:</p>
<p dir="auto">20:03:40   7963MB ERROR:<br />
Writing Redshift crash dump to C:\Users\joshe\AppData\Local\Temp\Redshift\20251010-200340-27928-22476.dmp<br />
20:03:40   7948MB DEBUG:<br />
Crash dump succeeded.<br />
20:03:40   7936MB DEBUG:<br />
Critical Error Detected<br />
Redshift encountered an unrecoverable error and has been disabled.<br />
Cinema 4D may be in an unstable state.<br />
We recommend you save your work and restart Cinema 4D.<br />
20:03:40   7935MB ERROR:<br />
We recommend you save your work and restart Cinema 4D.</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/2127/redshift-just-shat-itself-suddenly</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 09:38:56 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/2127.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Oct 2025 12:10:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Redshift just shat itself suddenly on Tue, 14 Oct 2025 06:42:31 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the reply and information, c4disstanky.</p>
<p dir="auto">Sounds like a corrupt project file. Sometimes it helps to copy the object manager content and paste it into a new file.<br />
If something like that works, I would also check the hard drives.</p>
<p dir="auto">Anyway, I'm not supposed to go into tech-support things here.</p>
<p dir="auto">I hope you get a clear answer from the tech Support.</p>
<p dir="auto">My best wishes</p>
]]></description><link>https://cineversity.forums.maxon.net/post/8247</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/8247</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Tue, 14 Oct 2025 06:42:31 GMT</pubDate></item><item><title><![CDATA[Reply to Redshift just shat itself suddenly on Tue, 14 Oct 2025 03:13:39 GMT]]></title><description><![CDATA[<p dir="auto">For those that have got the same error, I still dont know what it was.</p>
<p dir="auto">My workaround was to redo the take, delete the old one. It was something in there that maybe I changed? No idea.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/8244</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/8244</guid><dc:creator><![CDATA[c4disstanky]]></dc:creator><pubDate>Tue, 14 Oct 2025 03:13:39 GMT</pubDate></item><item><title><![CDATA[Reply to Redshift just shat itself suddenly on Fri, 10 Oct 2025 17:25:29 GMT]]></title><description><![CDATA[<p dir="auto">Hi c4disstanky,<br />
Sorry for your trouble.</p>
<p dir="auto">I have no manual workaround for this, which means, please check with tech-support:<br />
https://www.maxon.net/en/support-center</p>
<p dir="auto">My best wishes for a quick solution</p>
]]></description><link>https://cineversity.forums.maxon.net/post/8230</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/8230</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Fri, 10 Oct 2025 17:25:29 GMT</pubDate></item></channel></rss>
