<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Quickly change materials between takes with lots of parts.]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I've got an assembly with hundreds of different elements in my tree and about 90% of them need to have the same material, and that material changes between takes. These are different finishes for product offerings. Those 10% of parts are mixed into my model tree and not in one group. Since I don't want to merge the different parts in the tree to make one merged group and I can't just do a top level material tag override, what is the easiest way to change materials between takes? I see two options listed below, neither of which seem ideal. Can someone propose a better solution? Thank you.</p>
<ol>
<li>Go through the model tree and click and model tree material tag for each component with the correct material. This results in repeating the same operation hundreds of times.</li>
<li>In one material, use a material blender node to combine all different materials into one, and only have one of the materials actually being displayed using the blend color in the material blender node.</li>
</ol>
]]></description><link>https://cineversity.forums.maxon.net/topic/223/quickly-change-materials-between-takes-with-lots-of-parts</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 15:00:20 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/223.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 Jan 2023 16:16:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Quickly change materials between takes with lots of parts. on Wed, 18 Jan 2023 18:50:42 GMT]]></title><description><![CDATA[<p dir="auto">You're very welcome, Larson Monkey!</p>
<p dir="auto">Thanks for the feedback!</p>
]]></description><link>https://cineversity.forums.maxon.net/post/274</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/274</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 18 Jan 2023 18:50:42 GMT</pubDate></item><item><title><![CDATA[Reply to Quickly change materials between takes with lots of parts. on Wed, 18 Jan 2023 18:50:09 GMT]]></title><description><![CDATA[<p dir="auto">That worked! Thank you Dr. Sassi, I really appreciate your help and quick responses.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/273</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/273</guid><dc:creator><![CDATA[Larson Monkey]]></dc:creator><pubDate>Wed, 18 Jan 2023 18:50:09 GMT</pubDate></item><item><title><![CDATA[Reply to Quickly change materials between takes with lots of parts. on Wed, 18 Jan 2023 17:54:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi Larson Monkey,</p>
<p dir="auto">Select the Take you like to use; the little square needs to be active.</p>
<p dir="auto">Go to the Material that you like to overwrite. In the Material Manager&gt;Select&gt; Materials Tags/Objects</p>
<p dir="auto">In the Attributes Manager, the Material Field is grayed out. Right Mouse Click and use the "Overwrite" in the Fly out menu.</p>
<p dir="auto">Now, drag the new Material into the Material Field.</p>
<p dir="auto">Repeat this in new or other takes as you need to.</p>
<p dir="auto">Let me know how it goes.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/272</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/272</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 18 Jan 2023 17:54:01 GMT</pubDate></item></channel></rss>
