<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Help] Orthogonal Grid Particle Motion]]></title><description><![CDATA[<p dir="auto"><a href="https://cineversity.maxon.net/tutorials/05-particle-workflow-techniques-orthogonal-grid-particle-motion">View Tutorial</a><br />
<strong>Tag:</strong> <a href="https://cineversity.maxon.net/learn?filter=All&amp;product=Cinema-4D">Cinema 4D | 2024</a></p>
<ul>
<li>Other</li>
</ul>
]]></description><link>https://cineversity.forums.maxon.net/topic/2243/help-orthogonal-grid-particle-motion</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 06:26:08 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/2243.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 17 Jan 2026 14:13:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Help] Orthogonal Grid Particle Motion on Mon, 19 Jan 2026 11:11:08 GMT]]></title><description><![CDATA[<p dir="auto">Hi make-type,</p>
<p dir="auto">Is the Time Condition set correctly to establish the roundtrip every second?<br />
Less probable but perhaps an option for a problem, are you sending the particles back to the main Particle-Group Folder? If not, then that might be the problem.</p>
<p dir="auto">Could you please share your file, please, just as a C4D file (no compression - it should be below 1MB, greater is not possible here).</p>
<p dir="auto">You can also have a look at this file, which I have set up today<br />
<a href="/assets/uploads/files/1768811676025-cv4_2026_drs_26_parm_01.c4d">CV4_2026_drs_26_PArm_01.c4d</a></p>
<p dir="auto">Let me know how it goes.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://cineversity.forums.maxon.net/post/8762</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/8762</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Mon, 19 Jan 2026 11:11:08 GMT</pubDate></item><item><title><![CDATA[Reply to [Help] Orthogonal Grid Particle Motion on Sat, 17 Jan 2026 14:18:58 GMT]]></title><description><![CDATA[<p dir="auto">In a setup identical to the one shown in the tutorial, the particle turns once and then continues moving without turning. The setup is IDENTICAL to the one demonstrated.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/8756</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/8756</guid><dc:creator><![CDATA[make-type]]></dc:creator><pubDate>Sat, 17 Jan 2026 14:18:58 GMT</pubDate></item></channel></rss>
