<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Need Help with (UV&#x27;s) Property Transfer]]></title><description><![CDATA[<p dir="auto">I need to unwrap the UV's on various client product CAD files. That process works much better (especially as I'm using FD Toolkit to help) if I perform that task with a relatively low-poly model. Great. I can do this.</p>
<p dir="auto">However...</p>
<p dir="auto">I need to use much higher poly models, for the actual rendering work.</p>
<p dir="auto">So, I'm trying to use the Property Transfer tool to move the unwrapped UVW map, from the low-poly model, to the high-poly model. Things get messy from there. The UV's do seem to come across correctly, but I'm also stuck with weird artifact issues, around some of the model seams.</p>
<p dir="auto">I'm attaching the most simply, stripped-down, example of two pieces. One is the low poly (source) and one is the high poly (target).</p>
<p dir="auto">I hope someone can shed some light on this, for me.</p>
<p dir="auto">https://spaces.hightail.com/receive/IPq6ilHP4Z</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/2313/need-help-with-uv-s-property-transfer</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 17:03:54 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/2313.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Mar 2026 00:01:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Need Help with (UV&#x27;s) Property Transfer on Thu, 05 Mar 2026 16:10:18 GMT]]></title><description><![CDATA[<p dir="auto">Anybody? I can't be the only one who needs to make something like this work.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9063</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9063</guid><dc:creator><![CDATA[entry-newspaper]]></dc:creator><pubDate>Thu, 05 Mar 2026 16:10:18 GMT</pubDate></item></channel></rss>
