<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[C4D Particle Syste,  Scale over normalized life multiplied by Noise]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I'm trying the new C4D 2025 particle system for the first time. I would like my particles radius to follow a curve mapping based on their normalized age, but on top of this, I would like the radius to also be affected by a random noise.<br />
So far I have only been able to do one or the other, but not both.<br />
I tried:</p>
<ul>
<li>using 2x Data Mappers, one set to property with curve remap, second using fields with random field, but either way one of the mappers seems to be overridden?</li>
<li>using 1x Data Mapper, using Source: Property with Noise ticked, noise seems to override the life percentage mapping.</li>
</ul>
<p dir="auto">I want to modulate the size of the particle so it starts 0 radius, ends at 0 radius, but while its alive and radius is above 0, that value should be multiplied by noise.</p>
<p dir="auto">Thank you,<br />
Nik</p>
<p dir="auto">p.s. I was unable to post in the correct category, im not sure why this is showing in site issues, Im also not sure why my account is labled stock-foundation, i dont have control over my company cineversity account setup  so im not sure what the issue with naming/permissions might be?</p>
<ul>
<li>edit, just realised using property + age percentage controlling Radius and Noise Enabled ticked does modify after scaling to get the behaviour I was after</li>
</ul>
]]></description><link>https://cineversity.forums.maxon.net/topic/2376/c4d-particle-syste-scale-over-normalized-life-multiplied-by-noise</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 09:56:51 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/2376.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Jun 2026 11:25:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to C4D Particle Syste,  Scale over normalized life multiplied by Noise on Tue, 02 Jun 2026 12:51:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://cineversity.forums.maxon.net/uid/258">@noseman</a> this is awesome thanks for sharing!</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9284</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9284</guid><dc:creator><![CDATA[stock-foundation]]></dc:creator><pubDate>Tue, 02 Jun 2026 12:51:29 GMT</pubDate></item><item><title><![CDATA[Reply to C4D Particle Syste,  Scale over normalized life multiplied by Noise on Tue, 02 Jun 2026 11:58:24 GMT]]></title><description><![CDATA[<p dir="auto">The solution you found is the simplest one, but there's more ways to do it depending on your requirements.<br />
Here's an example of using the Data Mapper for the main Curve and then a Math that takes the Radius and multiplies it with a Random number with controls for the frequency (Animation Speed) etc.</p>
<p dir="auto">https://www.dropbox.com/scl/fi/jnfcg6yuoya9kogu4w5x8/Radius-Curve-Random-01A.c4d?rlkey=rvstd3lx7377cg9tc3y2i04bf&amp;dl=0</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9282</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9282</guid><dc:creator><![CDATA[noseman]]></dc:creator><pubDate>Tue, 02 Jun 2026 11:58:24 GMT</pubDate></item></channel></rss>
