<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Spacing between the instances is not uniform.]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I want to clone a cylinder object along a helix, but the spacing between the instances is not uniform.</p>
<p dir="auto">Is there a good way to distribute clones on any helix so that the distance between each instance stays exactly the same, without any manual adjustments or interaction?</p>
<p dir="auto">https://imgur.com/a/pc7rxPa</p>
<p dir="auto">C4D File:<br />
<a href="/assets/uploads/files/1781600629507-clone-on-helix.c4d">Clone on Helix.c4d</a></p>
]]></description><link>https://cineversity.forums.maxon.net/topic/2387/spacing-between-the-instances-is-not-uniform</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 20:51:01 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/2387.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Jun 2026 09:04:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Spacing between the instances is not uniform. on Tue, 23 Jun 2026 12:33:27 GMT]]></title><description><![CDATA[<p dir="auto">Thank you so much</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9357</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9357</guid><dc:creator><![CDATA[Kh]]></dc:creator><pubDate>Tue, 23 Jun 2026 12:33:27 GMT</pubDate></item><item><title><![CDATA[Reply to Spacing between the instances is not uniform. on Mon, 22 Jun 2026 10:01:54 GMT]]></title><description><![CDATA[<p dir="auto">Here's a Nodes Distribution that Scales the Clones while making the neighboring clone get closer and closer.<br />
It's not perfect, especially towards the center but for most part it holds up. You can define the clone count, the Y Scale and a Default Color. Also you can tweak the Scale to get them to touch or have some gap...<br />
https://www.dropbox.com/scl/fi/10yahy7iaaf8x86vq4hhs/cloned-size-no-Gap-01A.c4d?rlkey=k89v5tjd0ozggvxeiq42jwypu&amp;dl=0</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9354</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9354</guid><dc:creator><![CDATA[noseman]]></dc:creator><pubDate>Mon, 22 Jun 2026 10:01:54 GMT</pubDate></item><item><title><![CDATA[Reply to Spacing between the instances is not uniform. on Sat, 20 Jun 2026 08:09:49 GMT]]></title><description><![CDATA[<p dir="auto">Thank you  Noseman,<br />
Quick question:I'm trying to get a size gradient on Cloner instance (smaller toward the center) but with zero gaps, each clone touching the next, no overlap. Any clean way to do this in C4D?<br />
<a href="/assets/uploads/files/1781942982894-cloned-size.c4d">Cloned Size.c4d</a></p>
]]></description><link>https://cineversity.forums.maxon.net/post/9353</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9353</guid><dc:creator><![CDATA[Kh]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:09:49 GMT</pubDate></item><item><title><![CDATA[Reply to Spacing between the instances is not uniform. on Wed, 17 Jun 2026 10:23:57 GMT]]></title><description><![CDATA[<p dir="auto">The "Even" Distribution is correct because it measures the Spline distance between each clone.<br />
Here's one way to do it:<br />
Clone using Linear mode.<br />
Use Spline Effector to place them on a flat Helix<br />
Use a Step Effector to Raise them to the level you want.</p>
<p dir="auto">https://www.dropbox.com/scl/fi/pz7s65lu2tq4m8pk6o8x9/clone-on-helix-Fixed.c4d?rlkey=bmh6dgp5juiuewrqszkk30ds1&amp;dl=0</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9338</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9338</guid><dc:creator><![CDATA[noseman]]></dc:creator><pubDate>Wed, 17 Jun 2026 10:23:57 GMT</pubDate></item></channel></rss>
