<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rolling any object Problem!]]></title><description><![CDATA[<p dir="auto">Hi Masters,</p>
<p dir="auto">I'm trying to create an XPresso setup that lets any object roll automatically as it moves. However, I can't figure out what I'm doing wrong.</p>
<p dir="auto">The cube rolls correctly when I move it along the  X axis. But when I move it along the Z axis, it rotates around the  Y  axis instead of rolling correctly.</p>
<p dir="auto">Does anyone know what might be causing this?</p>
<p dir="auto"><img src="https://imgur.com/a/0KWX5Rj" alt="alt text" class=" img-responsive img-markdown" /></p>
<p dir="auto">Thanks!</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/2401/rolling-any-object-problem</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 18:20:26 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/2401.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 Jul 2026 13:27:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rolling any object Problem! on Sun, 12 Jul 2026 09:12:53 GMT]]></title><description><![CDATA[<p dir="auto">Hey everyone, just wanted to update this since I found the solution, in case anyone runs into the same issue in the future.<br />
The problem was that the Bounding Box node in XPresso doesn't read object dimensions properly when the object is still a Primitive. That's why the rotation was breaking and messing up on the Z-axis.<br />
As soon as I made the cube Editable (hit C), the Bounding Box node could finally read the actual geometry/vertices, and the automatic rolling now works perfectly on both X and Z axes!<br />
Thanks anyway!</p>
<p dir="auto">But there is a problem I faced witch is there is a little slideing when I move the  objects!<br />
any Ideas to fix it?</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9369</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9369</guid><dc:creator><![CDATA[Kh]]></dc:creator><pubDate>Sun, 12 Jul 2026 09:12:53 GMT</pubDate></item></channel></rss>
