<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[distribution type advanced in cloner object]]></title><description><![CDATA[<p dir="auto">Are there any tutorials on the new Clona distribution type?</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/2405/distribution-type-advanced-in-cloner-object</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Nov 2026 07:14:56 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/2405.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Jul 2026 13:01:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to distribution type advanced in cloner object on Fri, 31 Jul 2026 10:12:42 GMT]]></title><description><![CDATA[<p dir="auto">ok, thanks.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9391</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9391</guid><dc:creator><![CDATA[opinion-intention]]></dc:creator><pubDate>Fri, 31 Jul 2026 10:12:42 GMT</pubDate></item><item><title><![CDATA[Reply to distribution type advanced in cloner object on Fri, 31 Jul 2026 08:58:43 GMT]]></title><description><![CDATA[<p dir="auto">Unfortunately there are no tutorials yet.<br />
I assume you want to avoid the intersection of the boxes when the spline curves.<br />
The easiest solution for that is to add a Rigid Body Tag to the Cloner and set Follow Position and Rotation to 10. That way the Simulation will make sure the boxes don't overlap while the movement is followed.<br />
https://www.dropbox.com/scl/fi/j81wbkvo2zz4dj6pio6es/spline-distribution_0001-RBD.c4d?rlkey=e30cpnm2cczlvww4wj3677djs&amp;dl=0</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9390</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9390</guid><dc:creator><![CDATA[noseman]]></dc:creator><pubDate>Fri, 31 Jul 2026 08:58:43 GMT</pubDate></item><item><title><![CDATA[Reply to distribution type advanced in cloner object on Thu, 30 Jul 2026 14:50:12 GMT]]></title><description><![CDATA[<p dir="auto">I'm trying to arrange a group of boxes spaced o mm apart along a spline, as if they were on a ribbon. The problem is that I don't know how to do this on curves. I've noticed that with the new “Bead Distribution” cloning mode, the curves look good, but I'd like the boxes to be spaced apart along the curve so they don't overlap. I've tried using fields, but it doesn't work the way I want. Are there other methods? The boxes must be at a precise distance from each other, and I need to move them along multiple splines without using “Clone Count” and then moving the “End” to snap them together. “Spline Wrap” doesn’t work because it distorts the boxes.<br />
The boxes must always be perpendicular to the floor.</p>
<p dir="auto">thanks</p>
<p dir="auto">https://fromsmash.com/_UX0Mv_Hsj-dt</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9389</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9389</guid><dc:creator><![CDATA[opinion-intention]]></dc:creator><pubDate>Thu, 30 Jul 2026 14:50:12 GMT</pubDate></item></channel></rss>
