<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Constraint tag and protection]]></title><description><![CDATA[<p dir="auto">I'm creating a crankshaft-connecting rod rig (similar to this one). I'm sending the simplified project. There's an animation group that moves vertically. Inside it is Object A, which is pointing at Target B.<br />
Object B is outside this group and has a “Clamp” constraint tag pointing to Object A, as well as a “Protection” tag to make it move along track C. Unfortunately, it doesn’t work well because when the animation ends, the objects keep moving—I think due to lag. I’ve noticed that removing the “Protection” tag fixes this issue, but then the movements aren’t correct anymore. What can I do to make it work properly?<br />
https://fromsmash.com/qS7fDQv6.m-dt</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/2406/constraint-tag-and-protection</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 18:46:11 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/2406.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 31 Jul 2026 10:22:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Constraint tag and protection on Thu, 06 Aug 2026 10:46:22 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, that's exactly what I was looking for!</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9406</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9406</guid><dc:creator><![CDATA[opinion-intention]]></dc:creator><pubDate>Thu, 06 Aug 2026 10:46:22 GMT</pubDate></item><item><title><![CDATA[Reply to Constraint tag and protection on Mon, 03 Aug 2026 12:57:08 GMT]]></title><description><![CDATA[<p dir="auto">Which tutorial did you follow that shows a Protection Tag?<br />
Here's another way using Math. No need for Protection Tags:<br />
https://www.youtube.com/watch?v=s4fVHewn_IU</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9398</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9398</guid><dc:creator><![CDATA[noseman]]></dc:creator><pubDate>Mon, 03 Aug 2026 12:57:08 GMT</pubDate></item><item><title><![CDATA[Reply to Constraint tag and protection on Mon, 03 Aug 2026 08:49:58 GMT]]></title><description><![CDATA[<p dir="auto">I need to create this animation. I followed the tutorials on connecting rods, but it seems that the “protection” tag is causing a delay in the keyframes. When the animation keyframes stop, the objects continue to move or settle into position to reach their final destination.</p>
<p dir="auto">https://fromsmash.com/cbgF32bL8o-dt</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9396</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9396</guid><dc:creator><![CDATA[opinion-intention]]></dc:creator><pubDate>Mon, 03 Aug 2026 08:49:58 GMT</pubDate></item><item><title><![CDATA[Reply to Constraint tag and protection on Fri, 31 Jul 2026 11:03:41 GMT]]></title><description><![CDATA[<p dir="auto">I'm not sure exactly what you're trying to do, but here are some references for tutorials on these types of rigs:<br />
https://www.youtube.com/watch?v=6kmycdJjTkE<br />
https://www.youtube.com/watch?v=5dNmL-NpU_w<br />
https://www.youtube.com/watch?v=4sOTW4xYQvk<br />
https://www.youtube.com/watch?v=jGCRKX5Zz5M</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9393</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9393</guid><dc:creator><![CDATA[noseman]]></dc:creator><pubDate>Fri, 31 Jul 2026 11:03:41 GMT</pubDate></item></channel></rss>
