<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[issue with Mirror Tool in Polygon mode]]></title><description><![CDATA[<p dir="auto">Hi guys, I used to use the mirror tool without any problem. With the latest release I can't change the coordinate system and the mirror plane of the tool active in polygons mode</p>
<p dir="auto">Any help? thanks</p>
<p dir="auto"><a href="/assets/uploads/files/1787657845085-cinema_4d_bpnn1r714n.png">Cinema_4D_Bpnn1R714N.png</a></p>
]]></description><link>https://cineversity.forums.maxon.net/topic/2416/issue-with-mirror-tool-in-polygon-mode</link><generator>RSS for Node</generator><lastBuildDate>Wed, 02 Sep 2026 06:49:31 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/2416.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Aug 2026 11:38:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to issue with Mirror Tool in Polygon mode on Wed, 26 Aug 2026 10:24:28 GMT]]></title><description><![CDATA[<p dir="auto">That does sound odd. I think you may need to contact customer support and report this. Maybe it happens on some configurations.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9442</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9442</guid><dc:creator><![CDATA[noseman]]></dc:creator><pubDate>Wed, 26 Aug 2026 10:24:28 GMT</pubDate></item><item><title><![CDATA[Reply to issue with Mirror Tool in Polygon mode on Wed, 26 Aug 2026 09:43:57 GMT]]></title><description><![CDATA[<p dir="auto">Hi Noseman, here’s an update on my situation.<br />
I’ve run the following tests; you can view them at this link:</p>
<p dir="auto">https://youtu.be/S1EJ2N-VRzQ</p>
<ul>
<li>updated graphics card drivers</li>
<li>uninstalled C4D R2026</li>
<li>deleted the preferences folder</li>
<li>installed R2026 (releases: 2026.3.4, 2026.3.3, and 2026.3.2; one at a time)</li>
</ul>
<p dir="auto">but the problem persists across all versions.</p>
<ul>
<li>I installed the older version, 2025.3.3, and I have no issues with that one.</li>
</ul>
<p dir="auto">It seems strange to me that the problem would be related to my setup.</p>
<p dir="auto">For now, I’ll use R2025 for modeling.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9441</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9441</guid><dc:creator><![CDATA[head-notice]]></dc:creator><pubDate>Wed, 26 Aug 2026 09:43:57 GMT</pubDate></item><item><title><![CDATA[Reply to issue with Mirror Tool in Polygon mode on Tue, 25 Aug 2026 13:01:44 GMT]]></title><description><![CDATA[<p dir="auto">You're doing nothing wrong as far as I can see... this appears to be a glitch on your system right now.<br />
Do the usual, restart C4D, Restart PC, remove Preferences, reinstall C4D in a new Folder.</p>
<p dir="auto">One at a time <img src="https://cineversity.forums.maxon.net/assets/plugins/nodebb-plugin-emoji/emoji/twemoji2/1f642.png?v=7a11b27qclj" class="not-responsive emoji emoji-twemoji2 emoji--slightly_smiling_face" title=":-)" alt="🙂" /></p>
]]></description><link>https://cineversity.forums.maxon.net/post/9434</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9434</guid><dc:creator><![CDATA[noseman]]></dc:creator><pubDate>Tue, 25 Aug 2026 13:01:44 GMT</pubDate></item><item><title><![CDATA[Reply to issue with Mirror Tool in Polygon mode on Tue, 25 Aug 2026 12:46:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi Noseman, it's a pleasure talking to you (I'm a fan :)). I've uploaded a screenshot of the issue. I recall never having any trouble changing the plane or mode before. Now, the drop-down menu isn't available (at least not for me). What am I doing wrong? Thanks for the help.</p>
<p dir="auto">https://youtu.be/8kZ7mtu3O3Q</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9433</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9433</guid><dc:creator><![CDATA[head-notice]]></dc:creator><pubDate>Tue, 25 Aug 2026 12:46:39 GMT</pubDate></item><item><title><![CDATA[Reply to issue with Mirror Tool in Polygon mode on Tue, 25 Aug 2026 11:44:06 GMT]]></title><description><![CDATA[<p dir="auto">I just used it in 2026.3.4 and it works fine. Changed Mirror Plane and Coordinate system and it just works as expected.<br />
Can you elaborate a bit more?</p>
]]></description><link>https://cineversity.forums.maxon.net/post/9431</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9431</guid><dc:creator><![CDATA[noseman]]></dc:creator><pubDate>Tue, 25 Aug 2026 11:44:06 GMT</pubDate></item></channel></rss>
