<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[startup layout issue in 2027]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I've been using my startup layout for years now, but when migrating to Cinema 4D 2027 I'm having an issue with selected parametric objects displaying in the viewport. In the screenshots, you can see that when a parametric object is created or selected, it displays in solid gray color, when deselected, it shows shaded fine.</p>
<p dir="auto">Since I have more layouts based on my startup layout I use, it would be a pain to rebuild all of those layouts from scratch.</p>
<p dir="auto">Can you check my startup layout in your prefs and replicate the issue?</p>
<p dir="auto">https://www.dropbox.com/scl/fi/i37ql9do37jnnew2v0dy5/template.l4d?rlkey=rdh77gy106suyf3j9k3jdl54w&amp;dl=0<br />
https://www.dropbox.com/scl/fi/nfopkb4drpb1327v9tujn/viewport_selected.jpg?rlkey=kwdy2b3pzj5eequu6piqdad7w&amp;dl=0<br />
https://www.dropbox.com/scl/fi/kd5nki8v8a3ck2d8mgddj/viewport_deselected.jpg?rlkey=kt14bfroqgdbbwj6svfmca0tm&amp;dl=0</p>
<p dir="auto">Thank you.</p>
<p dir="auto">Best regards,</p>
<p dir="auto">DS</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/2434/startup-layout-issue-in-2027</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 23:00:21 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/2434.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 17 Oct 2026 00:27:30 GMT</pubDate><ttl>60</ttl></channel></rss>
