<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cloth Surface Thickness Causing Bevel Issues on Loft]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I'm using Cinema 4D 2027. I created a model with a Loft and added a Cloth Surface with 2 cm thickness. The thickness works on the main surface, but it causes distortion around the bottom Bevel.</p>
<p dir="auto">I've tried reversing the normals and adjusting the Bevel and Cloth Surface settings, but the issue persists.</p>
<p dir="auto">How can I fix this while keeping the bottom Bevel intact?</p>
<p dir="auto">Interestingly, this problem does not occur in Cinema 4D 2024. It seems to be specific to Cinema 4D 2025, 2026 and 2027.</p>
<p dir="auto">Has anyone experienced this issue or found a solution?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/2438/cloth-surface-thickness-causing-bevel-issues-on-loft</link><generator>RSS for Node</generator><lastBuildDate>Tue, 27 Oct 2026 09:00:02 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/2438.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Oct 2026 07:29:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cloth Surface Thickness Causing Bevel Issues on Loft on Tue, 27 Oct 2026 07:31:43 GMT]]></title><description><![CDATA[<p dir="auto"><a href="/assets/uploads/files/1793086300825-loft.c4d">Loft!.c4d</a></p>
]]></description><link>https://cineversity.forums.maxon.net/post/9500</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/9500</guid><dc:creator><![CDATA[Kh]]></dc:creator><pubDate>Tue, 27 Oct 2026 07:31:43 GMT</pubDate></item></channel></rss>
