<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Outline edge select either leaves a gap or jumps]]></title><description><![CDATA[<p dir="auto">When I try to do an outline edge select, the edge either leaves a gap or jumps to another side of just one polygon in the model, regardless how I construct it. Bridge, poly pen tool.</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/247/outline-edge-select-either-leaves-a-gap-or-jumps</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 22:16:12 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/247.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 29 Jan 2023 06:52:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Outline edge select either leaves a gap or jumps on Sun, 29 Jan 2023 21:44:17 GMT]]></title><description><![CDATA[<p dir="auto">Hi note-distribution,</p>
<p dir="auto">That sounds very annoying, but I can't reproduce this here; I would need a file to get your problem. With that, I can file a report. Perhaps find an individual workaround.</p>
<p dir="auto">https://help.maxon.net/c4d/2023/en-us/Default.htm#html/5642.html?TocPath=Select%2520Menu%257C_____5</p>
<p dir="auto">I understand it should provide an Outline selection even if nothing is selected. (Going by the old suggestion, if nothing is selected, everything is selected. The manual doesn't state that.</p>
<p dir="auto">Could you please check if this works:</p>
<p dir="auto">Select all polygons, just one, then use Select Connected.<br />
Then use the Outline Selection function.<br />
Is this working, or is there trouble at one point?</p>
<p dir="auto">Thanks for your patience with this.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/346</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/346</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Sun, 29 Jan 2023 21:44:17 GMT</pubDate></item></channel></rss>
