<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to Make Drop Down Icons]]></title><description><![CDATA[<p dir="auto">Hi All! This has been a burning question for me for a bit now. When I switch to my Redshift layout, the icons are never bundled together like they were in the normal one. To give an example, here is a screenshot:<br />
<img src="/assets/uploads/files/1677971369945-screenshot-2023-03-04-at-4.59.47-pm.png" alt="Screenshot 2023-03-04 at 4.59.47 PM.png" class=" img-responsive img-markdown" /></p>
<p dir="auto">How do you do this?</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/315/how-to-make-drop-down-icons</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 04:18:38 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/315.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Mar 2023 23:05:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to Make Drop Down Icons on Sun, 05 Mar 2023 06:07:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi jacobdesigns,</p>
<p dir="auto">If I set the application to Redshift in the Render Settings, the same four-part palette appears, as in your image.</p>
<p dir="auto">I have no idea from which release you have updated to 2023.1 has that menu.</p>
<p dir="auto">To answer your question, you can build your Windows and fill them with palettes. These palettes can have all the icons in the Command Manager. When assembled, you can set them in a vertical direction and use the Fold Pallete (right mouse click on the palette.<br />
You can save the palette, integrate it and save the Layout; otherwise, after one layout change, it will be gone.</p>
<p dir="auto">I stay on the standard Layout pretty much all the time. Perhaps setting shortcuts is much more efficient.</p>
<p dir="auto">More about customization<br />
https://help.maxon.net/c4d/2023/en-us/Default.htm#html/5225.html</p>
]]></description><link>https://cineversity.forums.maxon.net/post/630</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/630</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Sun, 05 Mar 2023 06:07:12 GMT</pubDate></item></channel></rss>
