<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Matrix Scatter and Object Bias]]></title><description><![CDATA[<p dir="auto">Is there a way to bias which objects are scattered more than others when using Matrix scatter with Redshift?!!</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/340/matrix-scatter-and-object-bias</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Mar 2026 05:09:35 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/340.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 Mar 2023 23:54:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Matrix Scatter and Object Bias on Thu, 16 Mar 2023 18:42:50 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very much, smckenzie, for the reply.</p>
<p dir="auto">Yes, it is a little bit more work, but also has way more control <img src="https://cineversity.forums.maxon.net/assets/plugins/nodebb-plugin-emoji/emoji/twemoji2/1f642.png?v=7a11b27qclj" class="not-responsive emoji emoji-twemoji2 emoji--slightly_smiling_face" title=":-)" alt="🙂" /></p>
<p dir="auto">If you want to double the amount of one clone, perhaps create a copy (in the Object Manager) and populate the list to get a different ratio among the results.</p>
<p dir="auto">There is always the option to submit this as an idea.<br />
https://www.maxon.net/en/support-center</p>
<p dir="auto">I think that should be an option to dial in percentages of distribution.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://cineversity.forums.maxon.net/post/770</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/770</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Thu, 16 Mar 2023 18:42:50 GMT</pubDate></item><item><title><![CDATA[Reply to Matrix Scatter and Object Bias on Thu, 16 Mar 2023 16:10:50 GMT]]></title><description><![CDATA[<p dir="auto">A bit more involved than I was hoping for but pretty cool though. Thanks again!</p>
]]></description><link>https://cineversity.forums.maxon.net/post/769</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/769</guid><dc:creator><![CDATA[smckenzie]]></dc:creator><pubDate>Thu, 16 Mar 2023 16:10:50 GMT</pubDate></item><item><title><![CDATA[Reply to Matrix Scatter and Object Bias on Thu, 16 Mar 2023 04:53:35 GMT]]></title><description><![CDATA[<p dir="auto">Hi smckenzie,</p>
<p dir="auto">The Matrix Scatter has no direct option for that. However, it is easy to split it up.<br />
Please have a look at the file below.</p>
<p dir="auto">The idea is that the Master Matrix sets the overall "clones". From there, other Matrix Objects take that information, and we make all other in-visible via a simple formula. Separation naturally allows for a lot of control.<br />
I used the formula mod(ID;10)=3 to give only a clone out when the ID of a clone divided by ten provides the reminder of three.<br />
You want double the amount, then mod(ID;10)=3 + mod(ID;10)=4 for example.<br />
Each of these Matrix/RS Object tags can hold several objects. So the variety is easily changed.</p>
<p dir="auto"><a href="/assets/uploads/files/1678941927017-cv4_2023_drs_23_rssm_01.c4d">CV4_2023_drs_23_RSsm_01.c4d</a></p>
<p dir="auto"><img src="/assets/uploads/files/1678942413284-screen-shot-2023-03-15-at-9.33.58-pm-resized.jpg" alt="Screen Shot 2023-03-15 at 9.33.58 PM.jpg" class=" img-responsive img-markdown" /></p>
]]></description><link>https://cineversity.forums.maxon.net/post/763</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/763</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Thu, 16 Mar 2023 04:53:35 GMT</pubDate></item></channel></rss>
