<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to auto switch off IPR when switching to another project]]></title><description><![CDATA[<p dir="auto">Hi, I set up a layout where the Redshift IPR is next to the viewport. I work with large projects. Most of the time I have several projects opened. When I switch from project 1 to project 2, I often forget that IPR in project 1 is still on. So switching to project 2 takes a long time because IPR is then also on in project 2. I was wondering if there is a way to auto switch off the Redshift IPR when switching projects.</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/379/how-to-auto-switch-off-ipr-when-switching-to-another-project</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 03:37:25 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/379.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 01 Apr 2023 10:13:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to auto switch off IPR when switching to another project on Mon, 03 Apr 2023 06:15:47 GMT]]></title><description><![CDATA[<p dir="auto">Hi shine-negative,</p>
<p dir="auto">This is one of those cases where I have to ask to contact the tech-support. I can't reproduce it here for the IPR.<br />
https://www.maxon.net/en/support-center</p>
<p dir="auto">Let me know if I do something that you don't or vice versa:<br />
https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2023_Clips_DRS/RS_IPR_cont_2023-2_RV-ipr.mp4</p>
<p dir="auto">OR do you mean the RS Render View? There I would have no idea how to stop that.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://cineversity.forums.maxon.net/post/961</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/961</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Mon, 03 Apr 2023 06:15:47 GMT</pubDate></item><item><title><![CDATA[Reply to How to auto switch off IPR when switching to another project on Sun, 02 Apr 2023 08:22:40 GMT]]></title><description><![CDATA[<p dir="auto">Please note: Both projects are already open in separate tabs.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/959</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/959</guid><dc:creator><![CDATA[shine-negative]]></dc:creator><pubDate>Sun, 02 Apr 2023 08:22:40 GMT</pubDate></item><item><title><![CDATA[Reply to How to auto switch off IPR when switching to another project on Sun, 02 Apr 2023 08:21:57 GMT]]></title><description><![CDATA[<p dir="auto">Hi Dr. Sassi, It is not really a problem. It is more of a question. I think I didn't explain well what I meant. The IPR itself is OK. It is the active render from the IPR that I meant. Suppose I work in project 1 and have the IPR rendering active and then want to switch to project 2. Then the IPR render will also remain active in project 2. And that can be annoying if you're in a hurry. Does this clear up things? Is this explanation clearer?</p>
]]></description><link>https://cineversity.forums.maxon.net/post/958</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/958</guid><dc:creator><![CDATA[shine-negative]]></dc:creator><pubDate>Sun, 02 Apr 2023 08:21:57 GMT</pubDate></item><item><title><![CDATA[Reply to How to auto switch off IPR when switching to another project on Sat, 01 Apr 2023 17:57:07 GMT]]></title><description><![CDATA[<p dir="auto">Hi shine-negative,</p>
<p dir="auto">I tried to replicate this here, but no luck. I tried all the Preferences combinations while keeping the camera name the same or changing it (just in case).<br />
It takes a moment, but then the current view is represented in the IPR. I checked as well the RS Render View. This is the same result even when I create a new GUI Template with the Render View.</p>
<p dir="auto">I can't recreate the problem, sorry.</p>
<p dir="auto">Please check with tech support<br />
]]></description><link>https://cineversity.forums.maxon.net/post/949</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/949</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Sat, 01 Apr 2023 17:57:07 GMT</pubDate></item></channel></rss>
