<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Strange issue with cut off pyro]]></title><description><![CDATA[<p dir="auto">Hello<br />
I think this is a bug, but posting it as a question anyways in case I'm missing something.<br />
Occasinally, but often enough for it to be a real problem, I render a pyro sim and end up having the top getting truncated, as if there was a collider.<br />
I tried playing with the padding, but it doesn't change anything.<br />
See screenshot and project files below...<br />
Let me know if this seems like a worthy bug report?</p>
<p dir="auto">Project:https://www.dropbox.com/s/6szcmvw6tcnadwn/TramBurner_0001.c4d?dl=0<br />
Image :https://www.dropbox.com/s/v1b42pwdl08a6pl/Tram_Seq2_0214.png?dl=0</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/430/strange-issue-with-cut-off-pyro</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 20:17:04 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/430.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 26 Apr 2023 16:40:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Strange issue with cut off pyro on Tue, 02 May 2023 19:09:45 GMT]]></title><description><![CDATA[<p dir="auto">Thank you, AlexC.</p>
<p dir="auto">Fingers crossed that it is solved in no time.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1293</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1293</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Tue, 02 May 2023 19:09:45 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue with cut off pyro on Tue, 02 May 2023 18:57:40 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Sassi!  Working it out with support now.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1292</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1292</guid><dc:creator><![CDATA[AlexC]]></dc:creator><pubDate>Tue, 02 May 2023 18:57:40 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue with cut off pyro on Wed, 10 May 2023 18:15:28 GMT]]></title><description><![CDATA[<p dir="auto">Hi Alex,</p>
<p dir="auto">Thanks for the file and using Drobox!</p>
<p dir="auto">I checked different parameter combinations.<br />
(MacBookPro, M1 Max, 64RAM).</p>
<p dir="auto"><img src="/assets/uploads/files/1682535719327-sizepad_pyro-resized.jpg" alt="sizepad_pyro.jpg" class=" img-responsive img-markdown" /></p>
<p dir="auto">Your image showed the problem at frame 214, so I explored frame by frame up to 215. No problem. I can't reproduce this problem.</p>
<p dir="auto">My tip is a quick check with 10cm and 2 padding to see if that, even in this rough resolution, is reproducible.</p>
<p dir="auto">Tip:<br />
https://help.maxon.net/c4d/2023/en-us/Default.htm#../Subsystems/Default/Content/html/Volume+Object.html</p>
<p dir="auto">Yes, check with tech support.<br />
https://www.maxon.net/en/support-center</p>
<p dir="auto">My best wishes</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1210</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1210</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 10 May 2023 18:15:28 GMT</pubDate></item></channel></rss>
