<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[C4D 2023 Save &#x2F; Open File Path Issue...]]></title><description><![CDATA[<p dir="auto">Hello all:</p>
<p dir="auto">I've recently upgraded to v2023, from R19.<br />
Silicone Mac, OS 13.3.1</p>
<p dir="auto">For as long as I've been using Cinema (R10) one of the best, most consistent aspects of the program, has been the way that it remembers the last place where a project file was last saved or opened, as too it would remember where renders were saved, etc.</p>
<p dir="auto">Now, with 2023, I'm finding that is no longer the case.</p>
<p dir="auto">For instance:</p>
<p dir="auto">I'm working in a project, and render something out to a specific "render" folder.<br />
If I then decide to "save as" a new version of the project, it will default to that render folder, instead of the project folder, where I previously had saved the current project.</p>
<p dir="auto">With every single version before, the default behavior would have been that C4D would remember where I last saved a project.</p>
<p dir="auto">Does this make sense?</p>
<p dir="auto">I don't know whether this has something to do with a change to C4D, or is related to Ventura?</p>
<p dir="auto">Thanks, for any advice possible.</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/466/c4d-2023-save-open-file-path-issue</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 00:36:57 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/466.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 May 2023 18:04:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to C4D 2023 Save &#x2F; Open File Path Issue... on Fri, 12 May 2023 21:27:17 GMT]]></title><description><![CDATA[<p dir="auto">You're very welcome, entry-newspaper.</p>
<p dir="auto">Little things, like a mosquito, can annoy as big things. I like to enable everyone to focus on the creative part of our work, not the tech-based problems.</p>
<p dir="auto">I enjoy the forum's work, as I know that every question solved (fingers crossed, your question as well) will help others at one point. Having the solution or at least the discussion here might save some time.</p>
<p dir="auto">As usual, a problem comes back until solved.</p>
<p dir="auto">So, thanks for your question and your patience, and please,</p>
<p dir="auto">Enjoy your weekend.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1375</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1375</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Fri, 12 May 2023 21:27:17 GMT</pubDate></item><item><title><![CDATA[Reply to C4D 2023 Save &#x2F; Open File Path Issue... on Fri, 12 May 2023 21:14:36 GMT]]></title><description><![CDATA[<p dir="auto">Hey, thanks for the detailed, thoughtful response. Very much appreciated!<br />
It's hardly a critical item, and I can certainly wait a formal response from Maxon support.</p>
<p dir="auto">And when I have the chance, I may try some those troubleshooting suggestions, thanks.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1374</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1374</guid><dc:creator><![CDATA[entry-newspaper]]></dc:creator><pubDate>Fri, 12 May 2023 21:14:36 GMT</pubDate></item><item><title><![CDATA[Reply to C4D 2023 Save &#x2F; Open File Path Issue... on Fri, 12 May 2023 20:38:09 GMT]]></title><description><![CDATA[<p dir="auto">Hi entry-newspaper,</p>
<p dir="auto">Thanks for the feedback. Which allows me to address this.<br />
To improve on many levels, Maxon-One meets close to the HQ once a year. Which was this week; this might have slowed down tech support response time. I hope you can see that such times will benefit everything in the long run, but yes, waiting for a reply is never a fun thing to do.</p>
<p dir="auto">Yes, google stuff or going through other public options are not fun, as they often have a lot of noise with a lot of advice that wasn't tried for a while, if at all, when quoted.</p>
<p dir="auto">Perhaps, investigating might help. One suggestion, set up a Child Render Setting, with a completely different output path, perhaps to a newly plugged in USB-stick. Now use the "save as" again. Does it point to the USB stick now? Whatever the outcome is, that might help to narrow the problem.</p>
<p dir="auto">Typically trashing the Preferences and restarting help, but I rarely suggest this, as from my experience, it works one out of ten times. Not something that I would just suggest and see what happens. It also falls under the umbrella of best guess items. If you know me, I love having a project file or something to retrieve a clear solution from. I do not answer from memory, as things can always change. Besides, no one knows everything, leading me to do practical tests in 99% of cases, which has worked for me in the past 19 years mentoring 3D artists, and for 17 years here. It is more work, but it works in a better way.</p>
<p dir="auto">Anyway, sorry for the delay with the support; I hope they can tell you more next week.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1373</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1373</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Fri, 12 May 2023 20:38:09 GMT</pubDate></item><item><title><![CDATA[Reply to C4D 2023 Save &#x2F; Open File Path Issue... on Fri, 12 May 2023 19:29:36 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
Thank you, for the rapid assistance. Before I posted here, I actually submitted this same question to Maxon Support. No response yet, however.</p>
<p dir="auto">I'm still in the beginning stages of setting up, and learning 2023 (HUGE differences from R19...) but I did try and set up the basic prefs, how I have prior. I'm wondering whether I set something wrong. But I don't recall there ever being anything about file paths.<br />
Are you aware of any hidden (C4D) settings, where I might at least check to see whether I have something toggled incorrectly?</p>
<p dir="auto">Googling is a little tough, because most of what I seem to dig up is in relation to tokens.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1372</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1372</guid><dc:creator><![CDATA[entry-newspaper]]></dc:creator><pubDate>Fri, 12 May 2023 19:29:36 GMT</pubDate></item><item><title><![CDATA[Reply to C4D 2023 Save &#x2F; Open File Path Issue... on Fri, 12 May 2023 19:11:57 GMT]]></title><description><![CDATA[<p dir="auto">Hi entry-newspaper,</p>
<p dir="auto">I checked it here on my test Mac with 13.4 (beta) installed. I created a render folder and a project folder. Rendered and then used the Save for a new project file version of my project. It pointed instantly to the Project folder.</p>
<p dir="auto">I tested it also on another M1 with 12.5; here, 2023 gives me no such problems.</p>
<p dir="auto">I googled your description, just in case I'm unaware of some developments.</p>
<p dir="auto">I checked my typical resources, nothing has shown up.</p>
<p dir="auto">This leaves the next step, checking with tech Support.<br />
https://www.maxon.net/en/support-center</p>
<p dir="auto">My best wishes</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1371</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1371</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Fri, 12 May 2023 19:11:57 GMT</pubDate></item></channel></rss>
