<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Key Frame  Animated Rigged Character from TurboSquid]]></title><description><![CDATA[<p dir="auto">I am trying to key-frame animate a rigged character purchased from TurboSquid. I haven't been able to find any online tutorials or videos about this. There are ton of tutorials on how to rig a character you have made, but not many on how to animate an existing rigged character. Any help would be appreciated.</p>
<p dir="auto">For some reason, when I go to rotate a joint, it makes a copy of the model rather than just manipulating the one existing.</p>
<p dir="auto">In the screen shot, I'm trying to animate the skeleton to wave. I select a point on the timeline, rotate around the joint and it makes a second arm instead of rotating the existing.</p>
<p dir="auto">If I can figure out how to properly manipulate the rigged character, than key frame animation is fairly simply.</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/495/key-frame-animated-rigged-character-from-turbosquid</link><generator>RSS for Node</generator><lastBuildDate>Thu, 15 Oct 2026 01:39:16 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/495.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 04 Jun 2023 14:55:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Key Frame  Animated Rigged Character from TurboSquid on Sun, 04 Jun 2023 19:07:13 GMT]]></title><description><![CDATA[<p dir="auto">Hi bird-opening,</p>
<p dir="auto">Images do not tell me a lot, but I can see it has two arms. I have no idea about this object, and Turbosquid has a few skeletons on its site. In other words, I don't know how it is created.</p>
<p dir="auto">There are two main options; why do you see two arms after rotating? The first one, the Command/Control key, was down (and has created a copy, or the setup has two skeletons and switches between the two to provide IK/FK options while avoiding a Joint based setup. Both are guesses, and nothing that I like to do here.</p>
<p dir="auto">So, go to the Object Manager&gt; Object&gt; Project Information, and check how many objects are in the scene. Close it. Rotate the other arm. Get the Project information again and check if there is now one more object.</p>
<p dir="auto">This will answer if you have a new copy or the setup is done this way. (While both are visible based on a setup, that would lead to problems later on. Again, these are just guesses. I would need to see it, but you can post it in public. You could send it to training@maxon.net, and I have a look at it. Please note, I do not move the discussion to email; that needs to stay here, so many people hopefully benefit from it.</p>
<p dir="auto">Animation can be done as Forward- or Inverse- Kinematic. Please have a look here<br />
https://youtu.be/rN_5weIhiMY</p>
<p dir="auto">You could also check out the Content Browser&gt; Skeleton.<br />
There you pick the Spline-based controllers, click and rotate or, in some cases, move them. Those Controllers get keyframed.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1496</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1496</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Sun, 04 Jun 2023 19:07:13 GMT</pubDate></item><item><title><![CDATA[Reply to Key Frame  Animated Rigged Character from TurboSquid on Sun, 04 Jun 2023 14:56:23 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1685890579782-c4d-issue-resized.png" alt="C4D ISSUE.png" class=" img-responsive img-markdown" /></p>
]]></description><link>https://cineversity.forums.maxon.net/post/1495</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1495</guid><dc:creator><![CDATA[bird-opening]]></dc:creator><pubDate>Sun, 04 Jun 2023 14:56:23 GMT</pubDate></item></channel></rss>
