<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[how do you edit VDBs?]]></title><description><![CDATA[<p dir="auto">I want to go through frame by frame and clean up a 30-frame-long VDB (delete little polygon blobs), but when I Make Editable I just get a single frame.</p>
<p dir="auto">thanks</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/576/how-do-you-edit-vdbs</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 09:33:57 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/576.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 Jul 2023 13:56:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to how do you edit VDBs? on Thu, 27 Jul 2023 18:13:59 GMT]]></title><description><![CDATA[<p dir="auto">Hi schnoidl,</p>
<p dir="auto">If I get your question correctly since your question leaves out all the details, you have imported a VDB sequence via VDB Loader and used the Volume Surface object to get polygons. If you used a 3rd party plugin for that, please check with the tech support/forum.</p>
<p dir="auto">Export your setup as an OBJ sequence (animated). Then reload it. There you get no option to delete a little polygon artifact. That is your question, correct?</p>
<p dir="auto">Check your sequence, and note the frames you like to work on.</p>
<p dir="auto">Switch off the Instance. Then twirl opens the hierarchy and sets the Display Tag so all your objects of that sequence become visible.</p>
<p dir="auto">The top object in that hierarchy to not visible (two red dots, Object Manager).</p>
<p dir="auto">Each frame you like to work on set to be visible (two green Dots, Object Manager)<br />
Create your changes.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1869</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1869</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Thu, 27 Jul 2023 18:13:59 GMT</pubDate></item></channel></rss>
