<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Symmetry mode and Coordinate manager]]></title><description><![CDATA[<p dir="auto">Hi. Why can't I change the position, size or rotation e.g. points in symmetric mode using coordinate manager? The mirrored side simply does not react to the change of numerical values. Only the directly edited symmetry side reacts. C4DR23 <img src="/assets/uploads/files/1690977503529-temp03-resized.jpg" alt="Temp03.jpg" class=" img-responsive img-markdown" /></p>
]]></description><link>https://cineversity.forums.maxon.net/topic/586/symmetry-mode-and-coordinate-manager</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Mar 2026 05:55:20 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/586.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 02 Aug 2023 11:59:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Symmetry mode and Coordinate manager on Thu, 03 Aug 2023 17:53:35 GMT]]></title><description><![CDATA[<p dir="auto">Hi hang-single,</p>
<p dir="auto">You're very welcome.</p>
<p dir="auto">Even if I can explain the problem, it doesn't mean it has to stay that way. So thanks for the question in the first place!</p>
<p dir="auto">I will file a report that the auto symmetry selection could be optional, and that would allow for the functionality you are after.</p>
<p dir="auto">If you like to support this, please "Share Your Ideas" here<br />
https://www.maxon.net/en/support-center</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1908</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1908</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Thu, 03 Aug 2023 17:53:35 GMT</pubDate></item><item><title><![CDATA[Reply to Symmetry mode and Coordinate manager on Thu, 03 Aug 2023 07:43:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://cineversity.forums.maxon.net/uid/13">@Dr-Sassi</a> Hi Dr., thank you for the explanation and advice<br />
All the best</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1907</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1907</guid><dc:creator><![CDATA[hang-single]]></dc:creator><pubDate>Thu, 03 Aug 2023 07:43:47 GMT</pubDate></item><item><title><![CDATA[Reply to Symmetry mode and Coordinate manager on Wed, 02 Aug 2023 22:37:45 GMT]]></title><description><![CDATA[<p dir="auto">Thanks a lot for the file.</p>
<p dir="auto">The two active points gave a hint, but I was not clear about what I saw in the image. Both Symmetry options look similar. While not knowing what geometry was given and which one was produced made it difficult to say anything.</p>
<p dir="auto">You used The Symmetry option from the top menu, not the Symmetry Object. Your object is already symmetrical. So when you select one point, you can move it; typically, the mirrored point moves as well as it is selected.<br />
This selection is in the way, from my point of view, to allow for parametrically input. As it is selected, it will move as the parameter suggests, but at the same time, it will also move to follow the symmetry, meaning it gets to work twice. This means the parametric adjustment would cancel each other out or double the movement. I hope that makes sense.</p>
<p dir="auto">That is different with the Symmetry Object; while only half of the object is given, the other mirrored side would "reflect" the entry. The Symmetry Object does not work very well with Symmetrically objects, so also not a way to go.</p>
<p dir="auto">My suggestion for your setup here: Use a Null or a Spline as a guide or anything that follows numerical input while allowing for snapping. Then snap one point of your setup to it. The "other" point will follow as wanted.<br />
https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2023_Clips_DRS/20230802_Symmetry_Function-v-Object.mp4</p>
<p dir="auto">Sorry to have no better idea right now.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1906</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1906</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 02 Aug 2023 22:37:45 GMT</pubDate></item><item><title><![CDATA[Reply to Symmetry mode and Coordinate manager on Wed, 02 Aug 2023 18:36:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://cineversity.forums.maxon.net/uid/13">@Dr-Sassi</a> I attach <a href="/assets/uploads/files/1691001404239-temp02.c4d">Temp02.c4d</a></p>
]]></description><link>https://cineversity.forums.maxon.net/post/1904</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1904</guid><dc:creator><![CDATA[hang-single]]></dc:creator><pubDate>Wed, 02 Aug 2023 18:36:49 GMT</pubDate></item><item><title><![CDATA[Reply to Symmetry mode and Coordinate manager on Wed, 02 Aug 2023 16:50:18 GMT]]></title><description><![CDATA[<p dir="auto">Hi hang-single,</p>
<p dir="auto">Images don't tell a lot, I can't see what the Symmetry settings are, nor what is symmetry based and what geometry is in the model already.</p>
<p dir="auto">Please share a file, below 1MB and as c4d, so it can be attached here directly. I'm happy to look into it.</p>
<p dir="auto">OR if you prefer, check with tech support:<br />
]]></description><link>https://cineversity.forums.maxon.net/post/1902</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1902</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 02 Aug 2023 16:50:18 GMT</pubDate></item></channel></rss>
