<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Projection Painting doesn&#x27;t work]]></title><description><![CDATA[<p dir="auto">Hello, I don't use the brush in Cineme 4D projection painting mode often, but sometimes it is necessary. But I can't use it, it doesn't work. It also happened to me on the old PC version. Now I have a new PC and it doesn't work either. What is going on in projection painting?<br />
Video: https://www.youtube.com/watch?v=REge6ylVybU</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/602/projection-painting-doesn-t-work</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Nov 2026 19:31:06 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/602.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Aug 2023 09:21:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Projection Painting doesn&#x27;t work on Wed, 16 Aug 2023 17:32:04 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the extra work, hang-single.</p>
<p dir="auto">I checked everything I could see in the interface, and nothing is left out on your side from what is visible. I typically ask for a file, as images and videos leave me guessing pretty much constantly. But here, I felt it might be more a limitation or hardware driven. Hardware things are not something I can simulate here for the innumerable combinations that are possible.</p>
<p dir="auto">What I couldn't see what your color management settings.</p>
<p dir="auto">I get different results here (I'm on Mac, and I have a different graphic card.), but I also have no option with Redshift while using RS materials.<br />
The Standard material works fine. However, if I switch the color management, it also changes here. This needs more technical attention, which I'm not supposed to provide here; that is the tech support area.</p>
<p dir="auto">I have tested it with all materials in the scene or only one each time.<br />
To have the same texture in two instances while painting in one might create problems when saving the texture.</p>
<p dir="auto">Since the Help Content is not limiting the use to Standard Render only, Please have a chat with tech support:<br />
https://www.maxon.net/en/support-center</p>
<p dir="auto">Thanks again for all the effort. I will file my report here. Perhaps you will hear that it is known, and that could be based on your input and my follow-up report.</p>
<p dir="auto">My best wishes.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1981</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1981</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 16 Aug 2023 17:32:04 GMT</pubDate></item><item><title><![CDATA[Reply to Projection Painting doesn&#x27;t work on Wed, 16 Aug 2023 10:17:52 GMT]]></title><description><![CDATA[<p dir="auto">Hi Dr., Thank you for your reply. There was no red X. I am sending another video https://www.youtube.com/watch?v=MYsqnAG5NsM</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1979</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1979</guid><dc:creator><![CDATA[hang-single]]></dc:creator><pubDate>Wed, 16 Aug 2023 10:17:52 GMT</pubDate></item><item><title><![CDATA[Reply to Projection Painting doesn&#x27;t work on Tue, 15 Aug 2023 16:25:37 GMT]]></title><description><![CDATA[<p dir="auto">Hi hang-single,</p>
<p dir="auto">Sorry to say that: I can see that you have excluded all parts of the interface in the screen capture that might lead to an answer. One would be the Material Manager. Does the Material inquest-ion have a red X or a green arrow?</p>
<p dir="auto">I checked it here, and it works; I can paint, detach it or not and apply it.</p>
<p dir="auto">Let me know if the texture was active (no red X)</p>
<p dir="auto">Cheers</p>
]]></description><link>https://cineversity.forums.maxon.net/post/1976</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/1976</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Tue, 15 Aug 2023 16:25:37 GMT</pubDate></item></channel></rss>
