<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[R16 GUI is  broken &#x2F; macOS 14]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I've updated my mac to macOS 14 Sonoma and discovered that my R16 GUI is  broken.<br />
When I'm hovering some GUI element, others GUI elements replicates this very  one element, which is hovered.  You can see better on my screenshots...<br />
Under macOS 13 Ventura everything is working just fine.<br />
Asked MAXON support about what could be the reason and how to eliminate such a behaviour,  but unfortunately they supposed to make an upgrade...<br />
I'll appreciate any reasonable looking idea to make my R16 work again.</p>
<p dir="auto">Thank you!</p>
<p dir="auto"><a href="https://www.dropbox.com/scl/fi/qo3zdxorhhj48h2f6vvom/cde_-1.jpg?rlkey=4id1985fkzxsxyrooszpf7v70&amp;dl=0">link text</a></p>
<p dir="auto"><a href="https://www.dropbox.com/scl/fi/pyzdmikibv7s523k7r625/cde_.jpg?rlkey=lhhbicrlt1atdxvcv5j3pur4i&amp;dl=0">link text</a></p>
]]></description><link>https://cineversity.forums.maxon.net/topic/618/r16-gui-is-broken-macos-14</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 16:04:40 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/618.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Aug 2023 11:40:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to R16 GUI is  broken &#x2F; macOS 14 on Fri, 25 Aug 2023 07:04:57 GMT]]></title><description><![CDATA[<p dir="auto">Hi plane-menu,</p>
<p dir="auto">All I can share is perhaps to install it newly; if you did that already, then I have no further suggestions. Sorry.</p>
<p dir="auto">I know the feeling of losing an app that moves one in no time into the zone (or call it flow), but either/or. I keep an old iMac here for that, which I will never update.</p>
<p dir="auto">P.S.: I will close this thread. Thanks for understanding.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2040</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2040</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Fri, 25 Aug 2023 07:04:57 GMT</pubDate></item><item><title><![CDATA[Reply to R16 GUI is  broken &#x2F; macOS 14 on Thu, 24 Aug 2023 18:53:18 GMT]]></title><description><![CDATA[<p dir="auto">Hi Dr. Sassi,<br />
thank you anyway for your kind suggestion. In reality it was the first thing I did. Unfortunately it doesn't help. I hoped that someone could know which system library is responsible for the GUI buttons and their behaviour, just to figure out from where I should begin to search for a helpful workaround possibly...<br />
So for now I still need help ))<br />
Kind regards!</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2035</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2035</guid><dc:creator><![CDATA[plane-menu]]></dc:creator><pubDate>Thu, 24 Aug 2023 18:53:18 GMT</pubDate></item><item><title><![CDATA[Reply to R16 GUI is  broken &#x2F; macOS 14 on Thu, 24 Aug 2023 18:26:43 GMT]]></title><description><![CDATA[<p dir="auto">Hi plane-meu,</p>
<p dir="auto">This is the site issue forum. Please use it for questions or problems regarding the site only. Thank you.</p>
<p dir="auto">R16 was published in 2014. No one could predict what we would do in 2023 back in 2014. A lot has changed.</p>
<p dir="auto">Mixing new OS and old apps is not suggested; based on the results, I assume you agree here. I'm not supposed to do tech support here for many good reasons.</p>
<p dir="auto">I have not tried it, nor do I have a system that will run MacOS 14 and has R16 installed, but a wild guess would be: how is it working after you installed Rosseta? There is no promise nor any further advice here; just a tip. Again, this is a wild guess!<br />
https://support.apple.com/en-us/HT211861</p>
<p dir="auto">My best wishes</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2034</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2034</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Thu, 24 Aug 2023 18:26:43 GMT</pubDate></item></channel></rss>
