<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Help] How to use the Flakes Shader in Redshift]]></title><description><![CDATA[<p dir="auto"><a href="https://cineversity.maxon.net/tutorials/redshiftquicktip-12-how-to-use-the-flakes-shader">View Tutorial</a></p>
<ul>
<li>Other</li>
</ul>
]]></description><link>https://cineversity.forums.maxon.net/topic/635/help-how-to-use-the-flakes-shader-in-redshift</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 08:51:04 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/635.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 31 Aug 2023 20:05:42 GMT</pubDate><ttl>60</ttl></channel></rss>
