<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Script path instead of call command in Python]]></title><description><![CDATA[<p dir="auto">Hi there, I have a question about a few lines of Python code in Cinema 4D. I have a functional script that executes my saved script via a button. However, sometimes the saved script changes the Command ID, causing the button to fail.</p>
<p dir="auto">Is there a way to specify the Command ID in my script or can someone rewrite it to execute based on the file path instead?</p>
<p dir="auto">Thank you for any possible solutions.</p>
<pre><code>
Code deleted. No Code in this forum.
Please use the Developer Forum Maxon.net Support</code></pre>
]]></description><link>https://cineversity.forums.maxon.net/topic/647/script-path-instead-of-call-command-in-python</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 05:55:15 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/647.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Sep 2023 05:48:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Script path instead of call command in Python on Fri, 08 Sep 2023 06:33:23 GMT]]></title><description><![CDATA[<p dir="auto">Hi sweet-boyfriend, You're very welcome.</p>
<p dir="auto">I hope you get what you need over there.</p>
<p dir="auto">My best wishes</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2146</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2146</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Fri, 08 Sep 2023 06:33:23 GMT</pubDate></item><item><title><![CDATA[Reply to Script path instead of call command in Python on Fri, 08 Sep 2023 06:30:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi Dr. Sassi, thanks for the guidance.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2145</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2145</guid><dc:creator><![CDATA[sweet-boyfriend]]></dc:creator><pubDate>Fri, 08 Sep 2023 06:30:22 GMT</pubDate></item><item><title><![CDATA[Reply to Script path instead of call command in Python on Thu, 07 Sep 2023 16:28:20 GMT]]></title><description><![CDATA[<p dir="auto">Hi sweet-boyfriend,</p>
<p dir="auto">For anything coding, please check the Developer Forum:<br />
https://plugincafe.maxon.net</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2140</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2140</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Thu, 07 Sep 2023 16:28:20 GMT</pubDate></item></channel></rss>
