<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Frontal UV Exporting AOVs without noise]]></title><description><![CDATA[<p dir="auto">I am trying to export my scene onto the UV of my object that I am then going to projection map back on to the object in real life. I am using baked sets and it's all working except that the AOVs are very noisy. Here is a an example: https://www.dropbox.com/scl/fi/0iy0o2rhthjn5w3k4e198/Frog_0001_AOV_Default_remesh_DiffuseLighting0003.tif?rlkey=wc1kv7gkiar4g9nieub0q4qkg&amp;dl=0</p>
<p dir="auto">I need to use a frontal UV projection and am wondering if there is a way to get the frontal UV to not get all noisy. When I export with a different UV it isn't noisy but all the content from the client has already been made for a frontal perspective.</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/736/frontal-uv-exporting-aovs-without-noise</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 14:11:06 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/736.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 22 Oct 2023 19:31:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Frontal UV Exporting AOVs without noise on Sun, 22 Oct 2023 20:53:44 GMT]]></title><description><![CDATA[<p dir="auto">Hi people-drama,</p>
<p dir="auto">The image can't be previewed or downloaded. It is not so important as images do not tell a lot. I need the project file, as those have all the settings. It is often the fastest way to find the problem, if not hardware-related. Noise can be a problem based on a low amount of samples.</p>
<p dir="auto">Frontal UV projection doesn't sound like a proper way to project things on real-built geometry. So I would like to see what you are doing.</p>
<p dir="auto">Have you set all the De-noise options for the AOVs?</p>
<p dir="auto">Render out larger than reduce often helps, or my tool of choice is Neat Image/Video for post-production.</p>
<p dir="auto">Enjoy you Sunday</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2473</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2473</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Sun, 22 Oct 2023 20:53:44 GMT</pubDate></item></channel></rss>
