<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[No Forum Access. Please fix.]]></title><description><![CDATA[<p dir="auto"><strong>Can pose morph target a selection of vertices rather than an entire mesh?</strong></p>
<p dir="auto">Hi,</p>
<p dir="auto">I was wondering if there was a way to make the pose morph tag target a selection of vertices on a mesh rather than affect the entire mesh?</p>
<p dir="auto">Or is there a way to lock a selection of vertices on a mesh so they are not affected by the pose morph tag?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/751/no-forum-access-please-fix</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 16:00:07 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/751.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Oct 2023 12:07:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to No Forum Access. Please fix. on Tue, 31 Oct 2023 17:39:04 GMT]]></title><description><![CDATA[<p dir="auto">Hi sun-youth,<br />
Let's clear the access first.</p>
<p dir="auto">Not to start a discussion here, NOT the place, but to give you a starting point:<br />
The simplest XPresso will work in a limited way and would require storing the points in objects.<br />
A more specialized setup would work with the Point numbers in a Python-based List and call up the vector data for points only. (Python is discussed in the Developer Café, not at Cineversity.<br />
Either way, many options in PoseMorph would require a lot of work. I do not see a real advantage in it.</p>
<p dir="auto"><img src="/assets/uploads/files/1698773942948-screen-shot-2023-10-31-at-10.27.26-am-resized.jpg" alt="Screen Shot 2023-10-31 at 10.27.26 AM.jpg" class=" img-responsive img-markdown" /><br />
However, the PoseMorph stores only Point values anyway (if that is the selected mode). To go with a lot of work and try to squeeze a few milliseconds out of the process seems counterintuitive.</p>
<p dir="auto">You might check the Cluster options instead. Again, this is not the place for any further discussion.</p>
<p dir="auto">Anyway, I hope the access is soon cleared for you, and you can ask in the F&amp;Q, not here please. Thank you.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2537</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2537</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Tue, 31 Oct 2023 17:39:04 GMT</pubDate></item><item><title><![CDATA[Reply to No Forum Access. Please fix. on Tue, 31 Oct 2023 09:38:43 GMT]]></title><description><![CDATA[<p dir="auto">Hi Dr. Sassi,</p>
<p dir="auto">Thanks for your reply.<br />
The drop down box would only let me select Site Issues for some reason. I tried again this morning and it's still the same. The Question and Answers section is not appearing as an option. I'm using google chrome.<br />
Could you please point me in the right direction of how to do this in Xpresso? I can't seem to find any documentation online. I found another old forum post from 2011 where someone was trying to lock vertices by using a python tag linking to a point selection tag but it didn't work for me.</p>
<p dir="auto">Thanks again!</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2534</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2534</guid><dc:creator><![CDATA[sun-youth]]></dc:creator><pubDate>Tue, 31 Oct 2023 09:38:43 GMT</pubDate></item><item><title><![CDATA[Reply to No Forum Access. Please fix. on Tue, 31 Oct 2023 04:13:14 GMT]]></title><description><![CDATA[<p dir="auto">Hi Sun-youth,</p>
<p dir="auto">Please post in the Q&amp;A. This Forum is for cases with problems with the Forum's access, for example.</p>
<p dir="auto">There is no option to limit a mesh and Pose morph that way. You can do that with XPresso.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2533</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2533</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Tue, 31 Oct 2023 04:13:14 GMT</pubDate></item></channel></rss>
