<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Editing a Weighted Mesh]]></title><description><![CDATA[<p dir="auto">It seems I've done this before, but I can find it in the documentation or forums.</p>
<p dir="auto">Using R21, I have a rigged weighted character with morphs. Sometimes, such as when working on textures in the UV Editor, I want to to see and select polygons in the character's current pose.  But every time I go into Polygon, Point, or Edge mode, the character goes into the initial rig pose.</p>
<p dir="auto">Isn't there a way to make Cinema4D not go into the initial pose and just stay in the same pose it was in Model mode?</p>
<p dir="auto">Bruce.</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/780/editing-a-weighted-mesh</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 01:31:31 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/780.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Nov 2023 21:12:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Editing a Weighted Mesh on Tue, 12 Dec 2023 21:51:09 GMT]]></title><description><![CDATA[<p dir="auto">Thanks a lot for taking the time, context-employ!</p>
<p dir="auto">Have a great day.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2909</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2909</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Tue, 12 Dec 2023 21:51:09 GMT</pubDate></item><item><title><![CDATA[Reply to Editing a Weighted Mesh on Tue, 12 Dec 2023 16:36:25 GMT]]></title><description><![CDATA[<p dir="auto">Hi Dr. Sassi,</p>
<p dir="auto">I finally found it, and it did what I needed!  Thanks.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2902</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2902</guid><dc:creator><![CDATA[context-employ]]></dc:creator><pubDate>Tue, 12 Dec 2023 16:36:25 GMT</pubDate></item><item><title><![CDATA[Reply to Editing a Weighted Mesh on Thu, 07 Dec 2023 06:10:52 GMT]]></title><description><![CDATA[<p dir="auto">Hi Bruce,</p>
<p dir="auto">Go to the Attribute Manager (Attributes).</p>
<p dir="auto">There is a menu; use the Mode menu.<br />
A list shows up and contains the View Settings.</p>
<p dir="auto">If you do not have an in the Layout an Attribute Manager, use Shift + F6</p>
<p dir="auto">or</p>
<p dir="auto">Go to the Main Menu and then to Windows<br />
In that list is an option to open the Attribute Manager.</p>
<p dir="auto">Is that helping?</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2816</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2816</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Thu, 07 Dec 2023 06:10:52 GMT</pubDate></item><item><title><![CDATA[Reply to Editing a Weighted Mesh on Thu, 07 Dec 2023 00:13:14 GMT]]></title><description><![CDATA[<p dir="auto">Hi Dr. Sassi,<br />
Sorry, but I can’t figure out how you got to that viewport attribute panel in the first place. I searched the online documentation for “Deformed Editing“ and yet to find how to get panel where that check box is.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2813</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2813</guid><dc:creator><![CDATA[context-employ]]></dc:creator><pubDate>Thu, 07 Dec 2023 00:13:14 GMT</pubDate></item><item><title><![CDATA[Reply to Editing a Weighted Mesh on Tue, 05 Dec 2023 23:10:04 GMT]]></title><description><![CDATA[<p dir="auto">Hi Greg,</p>
<p dir="auto">The Deformed Editing is precisely in that path you have in your post.<br />
R21<br />
<img src="/assets/uploads/files/1701817794676-r21_deformed.jpg" alt="R21_deformed.jpg" class=" img-responsive img-markdown" /></p>
<p dir="auto">Perhaps the Skin or the Pose Morph holds the shape in place, which is a guess. But my report came back as not reproducible.</p>
<p dir="auto">Workaround: Place the Object under a Connect object and switch the Weld option off. While the Connect object is selected and the Object is in the shape you need, use the Current State to Object option. This copy should be selectable. Create a Selection Tag and copy it to your model.<br />
OR<br />
Perhaps the Object stays in a deformed shape when in Object (vs Point) mode. Current State to Object as above, then select and copy the selection tag.</p>
<p dir="auto">To send a file, perhaps set up a small cube with a joint and a pose morph, and I will test it.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2804</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2804</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Tue, 05 Dec 2023 23:10:04 GMT</pubDate></item><item><title><![CDATA[Reply to Editing a Weighted Mesh on Tue, 05 Dec 2023 19:22:45 GMT]]></title><description><![CDATA[<p dir="auto">Hi Dr. Sassi,<br />
I must have a screw lose.  I can't find how you get to "Attribute Manager&gt;Mode&gt;View Settings&gt; Deformed Editing" (in R21).<br />
I couldn't figure out how to attach a file, and I can't get a c4d file smaller than 1mb.  I try describing a simpler example. I have rigged human head, and I move the mouth jaw joint so the mouth is open so I can make a polygon selection inside the mouth.  When I click the polygon mode button, and the head goes back to the mouth closed which is the rigging pose, and would do if I turned off the skin tag.</p>
<p dir="auto">Bruce,</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2803</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2803</guid><dc:creator><![CDATA[context-employ]]></dc:creator><pubDate>Tue, 05 Dec 2023 19:22:45 GMT</pubDate></item><item><title><![CDATA[Reply to Editing a Weighted Mesh on Sun, 12 Nov 2023 04:55:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi Bruce,</p>
<p dir="auto">I need a file to say anything with certainty; perhaps my setup here is different.</p>
<p dir="auto">When you like to work on UV Data, select only the UV tag, not the object itself – is that working for you?</p>
<p dir="auto">Typically, you go to Attribute Manager&gt;Mode&gt;View Settings&gt; Deformed Editing.</p>
<p dir="auto">I have set up a file, and at one point, it wouldn't stay deformed. I have no idea if I reproduced your problems here, but the only way to get it back to work was with the Connect Object on top of it. After that worked, the Connect object was no longer needed with the setting mentioned above.</p>
<p dir="auto">So, for anything else, please share the file, stripped to the bare minimum, to see the problem or share an example setup. I will have a look into it. (For the forum, it needs to be a c4d file and below 1MB; if you use a cloud service, please use Dropbox, Adobe, Apple, Wetransfer, or Google. If there is anything else I don't touch, thanks a lot.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/2617</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/2617</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Sun, 12 Nov 2023 04:55:22 GMT</pubDate></item></channel></rss>
