<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Vector Displacement in Redshift, ZBrush Diagnostic File]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">what would be the correct settings for vector displacement in C4D Redshift?<br />
I exported the Vector Displacement Diagnostic File from Zbrush to C4D Redshift, but i couldnt figure out the right settings.</p>
<p dir="auto">Thanks for your time.</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/915/vector-displacement-in-redshift-zbrush-diagnostic-file</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 16:10:37 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/915.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 24 Jan 2024 08:18:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Vector Displacement in Redshift, ZBrush Diagnostic File on Thu, 15 Feb 2024 18:18:57 GMT]]></title><description><![CDATA[<p dir="auto">You're very welcome, nothing-tennis.</p>
<p dir="auto">My best wishes for your project</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3424</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3424</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Thu, 15 Feb 2024 18:18:57 GMT</pubDate></item><item><title><![CDATA[Reply to Vector Displacement in Redshift, ZBrush Diagnostic File on Thu, 15 Feb 2024 11:52:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://cineversity.forums.maxon.net/uid/13">@Dr-Sassi</a> Thanks, great!</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3418</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3418</guid><dc:creator><![CDATA[nothing-tennis]]></dc:creator><pubDate>Thu, 15 Feb 2024 11:52:05 GMT</pubDate></item><item><title><![CDATA[Reply to Vector Displacement in Redshift, ZBrush Diagnostic File on Wed, 31 Jan 2024 08:16:07 GMT]]></title><description><![CDATA[<p dir="auto">Hi nothing-tennis,</p>
<p dir="auto">Sorry that you have trouble.</p>
<p dir="auto">I got weird results while the Displacement scale was anything but 1 and 1.</p>
<p dir="auto">Is that helping?</p>
<p dir="auto">I just have set it up again just now and compared it with the file from the post above<br />
https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2024_PROJECTS_DRS/20240131_CV4_2024_drs_24_RSzb_01.zip</p>
<p dir="auto">Cheers</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3255</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3255</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 31 Jan 2024 08:16:07 GMT</pubDate></item><item><title><![CDATA[Reply to Vector Displacement in Redshift, ZBrush Diagnostic File on Mon, 29 Jan 2024 07:45:49 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">thanks for taking the time!<br />
Unfortunately i dont get a round sphere (C4D 2024.2.0,  ACES 2065-1, the File IO is set to RAW, RS Object Tag has the "Enable Auto Bump mapping" disabled. UV and Normals: Smooth option, do you mean the Phong Tag ? Maybe you could share the scene file. Thanks!</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3224</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3224</guid><dc:creator><![CDATA[nothing-tennis]]></dc:creator><pubDate>Mon, 29 Jan 2024 07:45:49 GMT</pubDate></item><item><title><![CDATA[Reply to Vector Displacement in Redshift, ZBrush Diagnostic File on Thu, 25 Jan 2024 22:36:56 GMT]]></title><description><![CDATA[<p dir="auto">Hi nothing-tennis,</p>
<p dir="auto">For anyone reading along, the idea is to provide an evaluation platform that allows us to see what "pipeline settings" will work.</p>
<p dir="auto">The Vector displacement uses Red, Green, and Blue as X, Y, and Z values, seen as a movement from a previously non-displaced position. Often, applications have a color pipeline that tries to get the best guess about the color management used. But more importantly, as you can see when you explore the SNormal map channels, these channels are mixed in various ways. So, whatever one app prefers might end up eventually in a disaster in another.</p>
<p dir="auto">So, this diagnostic option helps to find out what works.</p>
<p dir="auto">The procedure,</p>
<p dir="auto">In ZBrush, Create Diagnostic Files.</p>
<p dir="auto">Ensure the RS Object Tag has the "Enable Auto Bump mapping" disabled. (Typical Displacement set up in RS 3D)</p>
<p dir="auto">I use the Tangent and 32bit/channel float as settings. This means that while my Project is set to ACES 2065-1, the File IO is set to RAW.<br />
UV and Normals: Smooth option.</p>
<p dir="auto">My result: 25 is the closest to a sphere.</p>
<p dir="auto"><img src="/assets/uploads/files/1706222213515-screen-shot-2024-01-25-at-2.33.48-pm-resized.jpg" alt="Screen Shot 2024-01-25 at 2.33.48 PM.jpg" class=" img-responsive img-markdown" /></p>
<p dir="auto">This data is then placed into ZBrush.<br />
Preferences &gt; Importexport &gt; FlipAndSwitch as well as Tangent FlipAndSwitch to this value.</p>
<p dir="auto">Which sets the pipeline for the render engine that was used.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3202</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3202</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Thu, 25 Jan 2024 22:36:56 GMT</pubDate></item><item><title><![CDATA[Reply to Vector Displacement in Redshift, ZBrush Diagnostic File on Thu, 25 Jan 2024 07:58:56 GMT]]></title><description><![CDATA[<p dir="auto">Hi nothing-tennis,</p>
<p dir="auto">Thank you very much for the files, and your patience with this. It is midnight here, and I will have a look in the morning into it.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3193</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3193</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Thu, 25 Jan 2024 07:58:56 GMT</pubDate></item><item><title><![CDATA[Reply to Vector Displacement in Redshift, ZBrush Diagnostic File on Thu, 25 Jan 2024 07:11:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://cineversity.forums.maxon.net/uid/13">@Dr-Sassi</a><br />
Hi,</p>
<p dir="auto">im not super familiar with the icloud service, it was set to:</p>
<p dir="auto">who has access: anyone with the link<br />
permission: can make changes</p>
<p dir="auto">i dont see further options, maybe we could give wetransfer a try?<br />
https://we.tl/t-Cd7TU1s4wS</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3191</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3191</guid><dc:creator><![CDATA[nothing-tennis]]></dc:creator><pubDate>Thu, 25 Jan 2024 07:11:39 GMT</pubDate></item><item><title><![CDATA[Reply to Vector Displacement in Redshift, ZBrush Diagnostic File on Wed, 24 Jan 2024 18:32:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi nothing-tennis,</p>
<p dir="auto">Could you please make this link downloadable? Sharing is not working for me.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3179</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3179</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 24 Jan 2024 18:32:58 GMT</pubDate></item></channel></rss>
