<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to decuple water drops condensation shader]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">See this material provided in the library. I don't have the slightest idea how to do this. There must be some reason for everything that is happening. It is a great learning opportunity to use advanced setups.</p>
<p dir="auto">Thanks<br />
Ricardo<br />
<img src="https://www.dropbox.com/scl/fi/rat2pbm0q67wm0barmrlp/Screenshot-2024-01-24-105830.jpg?rlkey=muxjjxqsrd91517q5vuvfrrhf&amp;raw=1" alt="alt text" class=" img-responsive img-markdown" /></p>
]]></description><link>https://cineversity.forums.maxon.net/topic/917/how-to-decuple-water-drops-condensation-shader</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Nov 2026 18:39:25 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/917.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 24 Jan 2024 14:00:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to decuple water drops condensation shader on Thu, 25 Jan 2024 01:28:32 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the feedback, Ricardo, which helps me to suggest this series:</p>
<p dir="auto">https://www.youtube.com/watch?v=ccIM7cbp-yk&amp;list=PLMeO87vDgOoMNIDy-OIqNBZeP7FrdlFiy</p>
<p dir="auto">Elly goes carefully through the Nodes, and next week is the next Episode:<br />
https://www.maxon.net/en/events<br />
During that show, you can ask questions, and perhaps you might be up to speed with these Nodes in no time.</p>
<p dir="auto">Enjoy</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3188</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3188</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Thu, 25 Jan 2024 01:28:32 GMT</pubDate></item><item><title><![CDATA[Reply to How to decuple water drops condensation shader on Thu, 25 Jan 2024 01:12:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi Sassi,<br />
Thanks for the introduction; it was a start, but there is so much going on behind this. At least for a beginner.<br />
I'd love to see some of the trainees setting up this from scratch on a webinar. There is so much to learn, IMO.</p>
<p dir="auto">My best wishes</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3187</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3187</guid><dc:creator><![CDATA[Ricardo 4D]]></dc:creator><pubDate>Thu, 25 Jan 2024 01:12:12 GMT</pubDate></item><item><title><![CDATA[Reply to How to decuple water drops condensation shader on Wed, 24 Jan 2024 19:22:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi Ricardo,</p>
<p dir="auto">Please have a look here:<br />
https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2024_PROJECTS_DRS/CV4_2024_drs_24_RSdr_01.jpg</p>
<p dir="auto">I have sorted the nodes a little bit for educational purposes.</p>
<p dir="auto">All the main input nodes are now on the left. Please note that this is not procedural; it is based on textures. Download the material, apply it to an object in the scene, and "Save Project with Assets, then take a look in the tex folder.</p>
<p dir="auto">The main setup is done in the larger "green" Group Setting Node. Here, the size options are crucial.</p>
<p dir="auto">Two significant things are happening here; one is that the whole setup is targeting a Triplanar projection. Which might not be needed for a Can, but it shouldn't hurt.</p>
<p dir="auto">Then, you have more exemplary tuning nodes in the middle field, e.g., Color Correct nodes, to set up different behaviors.</p>
<p dir="auto">If you don't use a Glass Pane, meaning just using a Plane of a Cylinder, perhaps switch to a Thin wall, but that will limit refraction if no displacement is set up (RS Object Tag&gt; Geometry).</p>
<p dir="auto">I hope that helps to get your exploration started.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3182</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3182</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Wed, 24 Jan 2024 19:22:12 GMT</pubDate></item></channel></rss>
