<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[360 Image Export from Cinema 4D]]></title><description><![CDATA[<p dir="auto">Hey everyone,</p>
<p dir="auto">In addition to C4D, I have been using "KeyshotXR" to export a sequence of rendered images that can then be imported to a number of platforms for interactive viewing on the web.</p>
<p dir="auto">Is there some way to accomplish this within Cinema 4D?</p>
<p dir="auto">KeyshotXR docs:</p>
<p dir="auto"><strong>[https://manual.keyshot.com/manual/keyshotweb/keyshotxr/](link url)</strong></p>
<p dir="auto">If you scroll down to the "Keyshot 360" section here, you will see an example. A sequence of images is pre-rendered.</p>
<p dir="auto"><strong>[https://www.keyshot.com/keyshot-web/#:~:text=a%20new%20tab-,KEYSHOT%20360,-Capture%20the%20motion](link url)</strong></p>
<p dir="auto">Keyshot tutorial that goes into detail and will give a better idea of what I'm attempting to achieve within C4D:</p>
<p dir="auto"><strong>[https://www.youtube.com/watch?v=kcQp8QSS8U0](link url)</strong></p>
<p dir="auto">Thanks so much in advance!<br />
Matt</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/943/360-image-export-from-cinema-4d</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Nov 2026 20:07:19 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/943.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 03 Feb 2024 00:29:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 360 Image Export from Cinema 4D on Sat, 03 Feb 2024 03:38:16 GMT]]></title><description><![CDATA[<p dir="auto">Hi Matt,</p>
<p dir="auto">The export for such content would be the glTF format from The Kronos Group.<br />
https://www.youtube.com/playlist?list=PLYO7XTAX41FNVFVQ2yS7JNAWYou5giSlH</p>
<p dir="auto">It can be used with available glTF viewers or embedded in a website.</p>
<p dir="auto">https://www.cineversity.com/vidplaytut/exporting_ar_game_ready_models_using_gltf<br />
Texture, as far as I can tell, works with the Standard Render setting, not Redshift.<br />
The player often used:<br />
https://gltf-viewer.donmccurdy.com/<br />
(Please note we have no control about web based player, or quality and security is not controlled by us.)</p>
<p dir="auto">https://help.maxon.net/c4d/2024/en-us/Default.htm#html/glTF_General.html?TocPath=Configuration%257CPreferences%257CImport%252FExport%257CglTF%257C_____0</p>
<p dir="auto">If you are looking for a 360º/180º image export (Equirectangular), use the Spherical camera and set the image to a 2:1 format (most apps like formats divideable by 2, e.g., a 1 K is typically 1024 [not 1000]).</p>
<p dir="auto">Cheers</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3304</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3304</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Sat, 03 Feb 2024 03:38:16 GMT</pubDate></item></channel></rss>
