<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Matrix Object MoSelection ID drives the &quot;Text Spline&quot; attribute of text object]]></title><description><![CDATA[<p dir="auto">Is there a way to programmatically fill the string of text within the “Text Object (previously MoText)” Text Spline attribute.  Specifically, I am needing to make a matrix object’s mograph selection ID(+1) to  drive the string value found in the Text Spline attribute.  I have created this with a single number in the Text Spline attribute, but can’t figure out how to programmatically change this value. In the end, I am trying to create a 20 sided die.</p>
<p dir="auto"><a href="/assets/uploads/files/1707172147998-d20.c4d">D20.c4d</a></p>
]]></description><link>https://cineversity.forums.maxon.net/topic/946/matrix-object-moselection-id-drives-the-text-spline-attribute-of-text-object</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 02:29:47 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/946.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 05 Feb 2024 22:29:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Matrix Object MoSelection ID drives the &quot;Text Spline&quot; attribute of text object on Tue, 06 Feb 2024 22:10:52 GMT]]></title><description><![CDATA[<p dir="auto">You're very welcome, appointment-insect!</p>
<p dir="auto">The Developer Café is a special forum for people who develop for and with Maxon Products.<br />
https://developers.maxon.net/forum/</p>
<p dir="auto">Off-Topic<br />
Thanks for asking</p>
<p dir="auto">I checked with DJI and got no positive reply or solution for this FAA requirement.<br />
Besides, the FAA has not replied on how to renew my registration, and no devices are easy to get.</p>
<p dir="auto">Weird times. My pilot license also needs a renewal, so I'm more or less "grounded" right now. <img src="https://cineversity.forums.maxon.net/assets/plugins/nodebb-plugin-emoji/emoji/twemoji2/1f609.png?v=7a11b27qclj" class="not-responsive emoji emoji-twemoji2 emoji--wink" title=";-)" alt="😉" /></p>
<p dir="auto">Cheers</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3325</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3325</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Tue, 06 Feb 2024 22:10:52 GMT</pubDate></item><item><title><![CDATA[Reply to Matrix Object MoSelection ID drives the &quot;Text Spline&quot; attribute of text object on Tue, 06 Feb 2024 21:41:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://cineversity.forums.maxon.net/uid/13">@Dr-Sassi</a> Thank you so much for you swift reply. I will investigate these suggestions. I am also pleased to see that the Maxon Developer's Cafe is a thing. I did not know there was such a thing. Thank you again. (Have you checked your drone for new firmware? My DJI Mavic 2 Pro supposedly has a new Remote ID firmware)</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3322</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3322</guid><dc:creator><![CDATA[appointment-insect]]></dc:creator><pubDate>Tue, 06 Feb 2024 21:41:27 GMT</pubDate></item><item><title><![CDATA[Reply to Matrix Object MoSelection ID drives the &quot;Text Spline&quot; attribute of text object on Tue, 06 Feb 2024 19:24:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi appointment-insect,</p>
<p dir="auto">The Cloner will take the Text Object as it is and reproduce it. There is no option to provide each Clone (based on a single Child for that Clone)  a different string with the Objects in the MoGraph "kit."</p>
<p dir="auto">(Perhaps check out the Maxon Developer's Café if someone has an idea to write code for that. Which is nothing that has a place here in the Q&amp;A forum, hence the special developer forum.)</p>
<p dir="auto">Place the Text object as many times under the Cloner as you have different text strings to use.</p>
<p dir="auto">Then, use the Modify Clone and define from there where which text is, perhaps with MoGraph Weight. The Weight Tag goes into the Field of the Plain Effector. The Plain Effector is set to Modify Clone to work with the Cloner set to Sort.</p>
<p dir="auto">The weight can be brushed on the clones with a fixed target value (Absolute) or with Add to paint several times until you get what you want.</p>
<p dir="auto"><a href="/assets/uploads/files/1707247476296-cv4_2024_drs_24_mgtx_01.c4d">CV4_2024_drs_24_MGtx_01.c4d</a></p>
<p dir="auto">I have placed some other little things in the file, more as a brainstorming base. Ignore it if it doesn't fit.</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3319</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3319</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Tue, 06 Feb 2024 19:24:39 GMT</pubDate></item></channel></rss>
